What type dump valve for sierra cosworth??
Old Apr 22, 2007 | 12:17 AM
Thanasis's Avatar
Thanasis
Default What type dump valve for sierra cosworth??
Hi,which is the best type of dump valve(BAILEY) for sierra cosworth?
1)single piston
2)twin pistons or
3) with diaphragm?
Which are from three dump valves works correct?
thanks a lot.
Old Apr 22, 2007 | 12:48 AM
All three will work correctly.
BAILEY DV's have given a lot of people a lot of trouble, diaphragm ones tend to be louder, but can split diaphragm's but last years before this happens and spares are cheap and easy.
Saying that piston ones especially BAILEY can jam.
Old Apr 22, 2007 | 05:47 PM
cossie604's Avatar
cossie604
If your going for a single piston or a diapraghm dump valve then get one with a filter as the cossie's lay out tends to suck the dumpvalve open at idle allowing unfiltered air into the inlet. Im using a twin piston Forge...have done for a few years with no problems.
Old Apr 22, 2007 | 06:13 PM
rapidcossie's Avatar
rapidcossie
I have GGR diaphram on mine and its good.
charliecosworth
Aug 19, 2015 02:00 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
155lee
Aug 14, 2015 11:21 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
