Cossie 4x4 front wheel bearings
As title says are they easy 2 do cause mine is really noisey.Are they the same as a 2wd sierra cause ive done 1 of these ages ago on my old sierra i used 2 own.
Don't know if the same bearing but easy to do, only this time there is a drivsahft to take out first that's all.
ps I am fairly sure they will be the same but not 100%, they could be a heavier duty version as having to transmit drive as well.
different bearings from my past experience
and also a bit of a skill to get just right otherwise you tend to strip the threads off teh end of teh shaft when you tighten it up again
easier to refit than to remove as you may need to get a puller to pull the hub off the end
on the other hand, they both tighten up the same way so
easiest to remove the nut and hub flange while everythign is on the car
then remove the hub assembly
when you put it back together again i found it's easier to put the cv back through the slot first and nip up the bearing before refitting the hub assembly to the car, bolting things back up again and then doing the torquing up on the nut
also, remove the brakes and you can then fit a steel rim to the car which means you can use the wieght of the car to turn the nut both for undoing an tightening up again
Originally Posted by tabetha
I tried to remove one(abs sensor) but gave up as it was braver than my wallet!!
Originally Posted by glennshute
Well im gonna take it off next week n have a go.Do the abs sensors normaly come out ok or do they snap.
but then again, they might not
if you are taking the bearings out anyway then you might be able to push them from the inside out, but you've got to be brave about it
sounds like a nightmare 2 me i hope it comes out ok.Does anyone know how tight the drive shaft nut has 2 be on the front.
That's the way I was taught to do it anyway when I was an apprentice
the way you say is for the split pin version, these ones need the nut staking/bent over to stop them from coming undone
Well ive got the hub off. A.B.S sensor seems tight need a new bottom arm cause ball joint rubber split.Went 2 start car 2 have a look n c where my oil leak is coming from,n now my engine wont start.i think fuel might b stickin.Bloody car
I took my hub off last nite n the but the wheel bolts 2 just come straight out of the bearing. I just hope its the bearing thats worn n not the bit the wheel bolts 2.All this hassle cause of my old buckled wheels.
Well i went 2 fit my wheel bearing today n found that the new bearing slides up n down the hub easily so i need a new hub now.110 quid from ford gonna get a complete hub with the bit the shocker bolts 2 n put the complete lot on.
Are you using a torque wrench or a big bar or are you using a impact gun?? Last time I did mine I just gunned the hub nuts up then used a chisel to knock the tab over on the nut.
I'm going to use torq wrench. There's contradicting information on the internet whether the nut should be torqued wheels on the ground or not. It apparently has an effect on how the bearing will seat in the hub. Does this make a difference?
