xr3 zetec conversion
Old Mar 30, 2007 | 11:45 AM
germanxr3's Avatar
germanxr3
Default xr3 zetec conversion
what has to be exactly done? I have found out that the zetec motor bolts straight in but the front engine mount I think has to be modified? If this is the case is there anywhere I can go to buy one? And the exhaust down pipe has to be modified but again not sure.I have the option of a zetec but its an auto will the flywheel off cvh motor fit? I need to know what sort of nightmare this is going to be before going to far
Old May 30, 2007 | 11:00 AM
xr2.0zetecturbo.'s Avatar
xr2.0zetecturbo.
so you did join up then
welcome anyway and i shall try and get on when you are later, whats the time difference there??
you'll be ok on here
steve
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
