ECU Transducer??
Old Mar 29, 2007 | 06:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default ECU Transducer??
I had my car RR'd today cos after 4500rpm the power would just fade away to nothing almost like i'd lifted off the pedal and i couldnt figure out why.
Amongst a few other things I was told that the transducer in the ingnition ECU (silver one) has gone and as a result the timing is about 10 degrees out when it reaches 4500rpm and so i need a new ECU.
What i need to know is:
Is the transducer the component in the ecu that the vacuum pipe goes onto?
and,
If so, can i get one from anywhere?
Otherwise I will have to get another standard ECU and fit my Ahmed Bayjoo chip into it, which looks fiddly!
Old Mar 30, 2007 | 01:14 PM
SafeChav's Avatar
SafeChav
Im pretty sure the transducer is the MAP sensor.
Its not going to be much easier to replace that tbh honest with you, both are going to need you to be confident at soldering.
Worst comes to worst im sure i could swap the chips over for you
Old Mar 30, 2007 | 01:25 PM
antony215's Avatar
antony215
Escort Rs Turbo
If you need another ecu ive got one for sale
Old Mar 30, 2007 | 02:19 PM
SafeChav's Avatar
SafeChav
Easy on the sales pitch?
You what.........come again................OHHHHHH you're not a registered trader
Old Mar 30, 2007 | 02:44 PM
antony215's Avatar
antony215
Escort Rs Turbo
You even get the fuel one
and it's cheap,cheap
Old Mar 30, 2007 | 02:50 PM
SafeChav's Avatar
SafeChav
Cheap & tacky?
Old Mar 30, 2007 | 02:56 PM
antony215's Avatar
antony215
Escort Rs Turbo
We are on about ECU's not your dress code
Old Mar 30, 2007 | 03:04 PM
SafeChav's Avatar
SafeChav
i was talkin about your car actually
Old Mar 31, 2007 | 04:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Landed another ECU going to fit it in a minute, fingers crossed!
Old Apr 1, 2007 | 10:01 AM
Karlos G's Avatar
Karlos G
Balls Deep!
ECU in, runs superb!
Also fitted new injectors and now starts first turn of the key from cold!
Old Apr 2, 2007 | 09:54 PM
SafeChav's Avatar
SafeChav
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
