Where can I get a TOSlink optical PCB header?
Old Mar 5, 2007 | 12:10 PM
Thrush's Avatar
Thrush
Irritating c........
Default Where can I get a TOSlink optical PCB header?
Like this - just the little black toslink "box" that I can fit to a PCB?
Basically, I have one of these;
http://www.maplin.co.uk/Module.aspx?...=97124&doy=5m3
But mines the later one without the optical audio output
Now, I took it apart and looked at the PCB inside - it still has the space and the holes in it for an optical toslink header.....
So, I was wondering if I got hold of the header itself, could I fit it to the PCB to see if the firmware still supported it?
Pic of PCB;
Optical header spot is far left, next to the VGA output...
Old Mar 5, 2007 | 12:59 PM
Eagle's Avatar
Eagle
Super Moderator
http://uk.farnell.com/jsp/endecaSear...sp?SKU=1225772
anyuse????
http://uk.farnell.com/jsp/search2/br...questid=175095
Old Mar 5, 2007 | 02:52 PM
Thrush's Avatar
Thrush
Don't know - doesn't show a picture
Old Mar 5, 2007 | 04:18 PM
Eagle's Avatar
Eagle
Super Moderator
look on the data sheet then
Old Mar 5, 2007 | 04:29 PM
Thrush's Avatar
Thrush
Don't know
Old Mar 5, 2007 | 04:41 PM
Thrush's Avatar
Thrush
Found this on Google;
Toshiba TOTX173 - Farnell's site doesn't list them tho.... Don't know if the 177 will do the same thing mind.... Seems that TORX is a reciever (input) and TOTX is a Transmitter (ouptut)....
But can't order off that site Eagle posted - as minimium order os £20 excluding VAT
Old Mar 5, 2007 | 05:36 PM
Eagle's Avatar
Eagle
Super Moderator
ok .. looked hard ..
and found
nothing really
can't beleive they are impossible to find in the uk .. how about a cheap sound card with one on from ebay or summit...
Old Mar 5, 2007 | 05:42 PM
Thrush's Avatar
Thrush
I thought that aswell - I have an optical soundcard, and they can be bought on ebay for less than a tenner - but a tenner is a lot of money if this don't work. And it's a lot fo money if I cannot remove the optical header from the soundcard with the pins intact
Old Mar 6, 2007 | 09:58 AM
Eagle's Avatar
Eagle
Super Moderator
shouldn't be that hard to do .. need to find out what voltage it supplies on the board... from what i have seen some require 3.3volts and some 5 volts
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dickdastardley
Sep 24, 2015 08:43 PM
