removing an esc cos rear fin?
2 bolts either side of the boot lid high up and one long one through the centre piller accessed from behind the boot lid trim, this bolt is very long and can be a bit fiddly to remove.
steve
steve
How are these removed? just bolts inside the boot?
is it easy to remove for a while?
cheers
cheers
Dave, are you doing a top speed run somewhere? Brunters?......A127/M25?
On an engine spec like yours we're prob talking an extra 14 - 18 MPH sans wing
Be carfull,we all know what happened to Martin and Porkie on the gumball when they took the rear spoiler off!!!!
Was talkin to someone about them,and its unreal the downforce that they produce over 100mph!!!
Good luck on ya run though!
Pete.
Pete.
Pete.
Pete.
="Doug Stirling
on an escos that can pull over 180mph removing the rear wing will give another 3-4 mph
HTH
Originally Posted by Kevin Sharp
="Doug Stirling
HTH
Does removing the rear wing not make more difference to the top speed (due to less drag) the less power you have?
I.E. a standard T25/28 (220 BHP) Es Cos would show the biggest IMPROVEMENT is top speed without wing??
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
