Water Injection set-up question's!
After becoming the new owner of an Aquamist WI kit ( cheers Spadge
) im wondering where the best place under the bonnet would be to situate the pump?
Also where would be the most ideal place for the water jet?
Any pics would be most helpful!
Its a Saph rwd cos btw!
The water jet goes just in the out let pipe from the intercooler on the inlet side of the engine.
mount the pump somewhere away from heat if poss as its quite hot when running
cheers mate, wasnt sure if the best place was b4 the throttle body or after!
What would you think about mounting the pump above the Rad? Ive got an rs 500 intercooler with pace rad so theres room above there!
go on the web site for aqua mist mate and down load the instructions for installation because the pump must not be more than a certain height above the bottom of your water storage tank I think mines on the chassis leg.
but check the literature http://www.aquamist.co.uk/cp/cp.html
to make sure you get the pump int he right place, intercooler side of throttle body defo to give the mist time to get well spread
Mark RS
Oct 12, 2015 06:01 AM
