new products alternative to loctite
Old Sep 10, 2004 | 03:17 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
Default new products alternative to loctite
this range of products is made by loctite for a company called adesco and are marketed at almost half the price of loctite they have been tested by myself and stu@motorsport developments on my engine which no bolts have fallen out of aand the glue well thats truley awesome!
Old Sep 10, 2004 | 03:21 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Methinks I might need some of that
Where can you get it from ?
Old Sep 10, 2004 | 03:26 PM
Rs Gus's Avatar
Rs Gus
me
Old Sep 10, 2004 | 03:37 PM
cossiemen's Avatar
cossiemen
Whassup
the same product but a lot cheaper, happens many times
Old Sep 10, 2004 | 04:07 PM
Rs Gus's Avatar
Rs Gus
Old Sep 10, 2004 | 04:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
Ok Guys,
Some time ago the Rep from Adesco products asked me to use some of this in place of the Loctite products i normally use so ive done just that on a couple of engines and had no problems so far with each tyope of product performing faultlessly and as expected so far.. but more scientifically i have tested various types of fastener with this product against my normal Loctite equivalent and can confirm it does seem to show exactly the same properties, including the all important "Crack off test"
Test 1:
1) Tighten bolt to 30Lb.
2) Wait 15 mins.
3) Check torque required to crack off. (47lb)
4) Apply stud lock. Retorque to 30lb.
5) Wait 15mins
6) Check torque required to crack off. (71lb )
Notes:
1) Product certainly cures well and adheres the fastener in place.
2) Stu uses too much of it
Test 2: (Glue)
1) Cut rubber fuel line clean in 2.
2) Apply glue as instructed to both surfaces.
3) Hold together for 30 seconds.
4) Get hold of each end with mole grips and try to pull apart.
5) Get Gus to take over one end and try again.
6) Repeat above using a vice cos we cant get enough grip.
7) Give up... fooking fantastic stuff.. ive glued loads with it now
Notes:
1) Dont apply to surfaces you dont want it on. (Fingers )
2) Dont let Gus loose with Glue
Seriously though:
The products are certainly far more technical than this in reality but thats all teh end user needs to know as thats all it has to do for us, we need it to keep a fastener torqued to the setting we left it at under all manner of adverse conditions from heat to severe vibration. Adesco certainly works and will be my checmical of choice from now on as its MUCH cheaper than the other market leaders!!
Anyone wishing to purchase some (And you should if your assembling important and expensive components) can obtain it at a great price from here:
Adesco, 3 Edmund Road, Sheffield:
Call 0114 275 5884 and ask for Dan Lynch.
(Mention PF and im sure he will do you a favourable rate!)
Old Sep 10, 2004 | 04:11 PM
Rs Gus's Avatar
Rs Gus
cool
oh yes or kenny will end up on the floor
Old Sep 10, 2004 | 04:12 PM
frog's Avatar
frog
Ohhhh, don't I know that ?
Old Sep 10, 2004 | 04:23 PM
frog,
Problems mate?
Old Sep 10, 2004 | 04:28 PM
Rs Gus's Avatar
Rs Gus
frog,
Problems mate?
someone didnt put some on his cam pulley bolts m8 and one come out ouch
Old Sep 10, 2004 | 04:42 PM
Wounder... very common too unfortunately
Old Sep 10, 2004 | 04:44 PM
GARETH T's Avatar
GARETH T
cant fault that,,, half the price of locktite! if i didnt get my locktite products for free i would buy a bottle !
Old Sep 10, 2004 | 04:51 PM
markk's Avatar
markk
i too have tested these products and can concuur with the above , have built 2 engines with the aid of the above and one of them was in my rally car !!! have had no bolts vibrating out or loss of torque !! excellant stuff well recommended !!
Old Sep 10, 2004 | 05:06 PM
Rs Gus's Avatar
Rs Gus
Old Sep 10, 2004 | 11:36 PM
Rs Gus's Avatar
Rs Gus
Old Sep 11, 2004 | 08:42 AM
Rs Craig's Avatar
Rs Craig
land of the rising sun
From: sheffield,home of james toseland world superbike champion
cheers guys this stuff was given to a few people to test as were now trying to sell it to the automotive industry. the results speak for themselfs why pay twice as much for loctite when this stuff is just as good..
Old Sep 13, 2004 | 08:13 PM
Rs Craig's Avatar
Rs Craig
up
Old Sep 13, 2004 | 08:40 PM
ballin's Avatar
ballin
wickedy dickedy, ill get some
Old Sep 13, 2004 | 09:26 PM
Thrush's Avatar
Thrush
Irritating c........
BLATANT
Old Sep 13, 2004 | 09:28 PM
Rs Gus's Avatar
Rs Gus
Originally Posted by Thrush
BLATANT
seen as stu was one of the ones who was given it to test YES it is thrush
Old Sep 25, 2004 | 10:42 AM
jonfoc
16
Sep 11, 2018 05:35 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
jay030787
Sep 18, 2015 04:38 PM
