P100 conversion Q's
Old Feb 21, 2007 | 07:22 PM
cosrep's Avatar
cosrep
Default P100 conversion Q's
A mate is interested in converting his P100 to run cossie mechanicals, As far as I can see the front end of both cars is identical so problems there.
Will the rear end bolt up or will some fabrication be required to fit the rear beam?
Would the prop shaft be the correct lenght?
Do the P100's use the standard ford PCD for wheels?
Old Feb 21, 2007 | 07:57 PM
P100 PCD is unique, to fords anyway, same as TRIUMPH and a few others but not many.
A lot of fabrication is needed as you are going from a live axle to to an axle with (semi) trailing arms, and IRS.
Prop will need stengthening with CJ13 joints.
Old Feb 22, 2007 | 07:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
as said, p100 uses live axle and 5 stud pattern
Old Feb 22, 2007 | 08:54 AM
rog's Avatar
rog
There is or was a P100 rolling shell on ebay the other day, it did have full 4x4 cossie stuff in it, just get a hold of that and save some grief???
Old Feb 22, 2007 | 05:52 PM
GOOD idea, save a lot of greif and expense.
Old Feb 22, 2007 | 06:31 PM
whoopty's Avatar
whoopty
Hi bud im currently converting a p100 iv finished the back axle and there is a bit of fabricating to do, you would need to shorten the p100 shaft to fit
or you could lengthen he cosi one but it could end up 2 long and twist if alot of power goes through it
Old Feb 22, 2007 | 10:09 PM
cosrep's Avatar
cosrep
Cool any chance you could post a pic or 2 of the rear end taken from underneath?
Old Feb 23, 2007 | 05:44 PM
whoopty's Avatar
whoopty
no problem ill try and get some sorted within the next few days
Old Mar 5, 2007 | 06:56 PM
LOWSCORTS's Avatar
LOWSCORTS
I'm doing a P100 and im fitting efi to the pinto thats in it for now, but I have a couple of questions.
Are the feed and return lines large enough in the tank sender for the injection using a normal ford efi pump or if not is there a sender that will fit the tank with the right size in/out?
I'm using a Sierra engine loom, which I haven't got to connecting yet, but is the wiring there in the P100 loom for the fuel pump/ECU relays to the fuse box or do I wire it all in seperately as I would in a MK2 escort etc ?
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
