can some one explain 'turbo specs' please?
Old Sep 9, 2004 | 08:58 PM
Moose 130's Avatar
Moose 130
Default can some one explain 'turbo specs' please?
I know a little about this, but you know what they say about a little knowledge......
whats the difference between a .48, .55, .60 exhaust housing? is it smaller number = less lag but less top end power?
size of the compressor wheel effects what?
Trim? whats the differencebetween 52 or 56 trim in the turbos performance?
I assume the compressor maps require the flow rate of a head and the required pressure and you work off of an area of the map.
If anyone can explain some of this SIMPLY I would be thankfull.
Old Sep 9, 2004 | 09:13 PM
JamesH's Avatar
JamesH
Would like to also know this
Old Sep 9, 2004 | 09:28 PM
Jon ERST S2's Avatar
Jon ERST S2
The larger the Exhaust housing the more lag but less restrictive it is. 0.48 is the size.
Trim is the size of the compressor.
Old Sep 9, 2004 | 09:29 PM
GUZZLER's Avatar
GUZZLER
where is the exhaust housing marked?
Old Sep 10, 2004 | 06:16 AM
Moose 130's Avatar
Moose 130
bttt until we get some answers.
Old Sep 10, 2004 | 06:21 AM
Jon ERST S2
The larger the Trim the more air it can flow.
Old Sep 10, 2004 | 06:45 AM
Moose 130's Avatar
Moose 130
so far then-
a .48 exhaust housing will give less lag and also less top end power due to restriction than a .55 or .63
Trim is the size of the compressor but is that the wheel or housing inlet? will a large trim and a small exhaust housing fight each other upon operation??
Is trim and the compressor wheel size related directly?
Old Sep 10, 2004 | 07:09 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
bttt. Am also interested in this. Maybe stu could do one of his layman terms essays?
Old Sep 10, 2004 | 07:52 AM
Shell's Avatar
Shell
as weare on the wondering subject... i have always pondered about what bttt means? Nothing to do with turbos tho ha ha ha
Old Sep 10, 2004 | 07:53 AM
Uncle Henry's Avatar
Uncle Henry
Back To The Top
Old Sep 10, 2004 | 04:59 PM
the strut brace's Avatar
the strut brace
bttt coz i wanna know too
Old Sep 10, 2004 | 07:14 PM
Moose 130's Avatar
Moose 130
still in need....
Old Sep 10, 2004 | 07:21 PM
JamesH's Avatar
JamesH
Old Sep 10, 2004 | 07:24 PM
Rolls's Avatar
Rolls
One for the FAQ????
Stu @ M Developments's Avatar
PassionFords Creator
Good lord.. all these questions... not sure ive consumed enough beer to do an essay like this just yet.....
Old Sep 10, 2004 | 07:34 PM
Eagle's Avatar
Eagle
Super Moderator
Originally Posted by Moose 130
still in need....
no comment beardy
but this could be a good post ... once stu has had enough to drink ...
hmmm .. now there is a thought .. drink+passionford = oh bugger im banned again
Old Sep 10, 2004 | 07:37 PM
Have you all read the:
"How a large turbo makes more power than a small turbo with the same boost pressure" essay i wrote?
Its very relevant
Old Sep 10, 2004 | 07:47 PM
Eagle's Avatar
Eagle
Super Moderator
ermmmmmmmmmmmmmm ... nope
so ok .. on another tangent ..
if you have a stage 3 chip set up to a standard t3 turbo (cossie) but then want to change it for a t 35/34 .. i would suspect that the fueling pressure would have to be increased???
Old Sep 10, 2004 | 07:55 PM
JamesH's Avatar
JamesH
is that the fookin massive one stu ?
Old Sep 10, 2004 | 08:09 PM
Moose 130's Avatar
Moose 130
Thats the one about shifting a larger volume of air etc etc.
Really just a quick knock down of what the relivant numbers relate to in performance.
Really simple not techie talk please.
Lets not get this into teh Q&A section as I don't think many people go there.
Old Sep 10, 2004 | 08:14 PM
Cosworth Cortina's Avatar
Cosworth Cortina
Buy this book.... forced induction performance tuning by A. Graham Bell ....do a search on www.amazon.co.uk top book at it'll answer all your questions simpily and in plain english...
Old Sep 11, 2004 | 04:05 PM
Eagle's Avatar
Eagle
Super Moderator
so .. what was the outcome
Old Sep 14, 2004 | 08:42 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
for craig (Although most of it will go over my head, I'd love to know...).
Old Sep 14, 2004 | 08:44 PM
Well some of the essay required has ended up here:
https://passionford.com/forum/viewtopic.php?t=73030
SmudgerByName
52
Jul 28, 2016 06:14 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
RsS2daz
Aug 14, 2015 05:26 AM
