xr3i efi wont run right
Old Feb 10, 2007 | 05:49 PM
stevemex's Avatar
stevemex
Default xr3i efi wont run right
Bought an h reg xr3i mk4 last week had a look at it last night to see what the problem was .
It starts straight away but wont take full throttle have to gently press it and the revs go as far as 4 - 5k then it bogs down , its imposible to drive .
Had a search on other threads but couldnt find a solution .
So far i have changed the plugs and leads and a working coil pack from another xr2i and the fuel filter and the throttle position sensor and still the same problem .
the fuel pump sounds like its working unpluged the pump relay and it wont start at all .
Any ideas ? as its driving me up the wall ?
Old May 21, 2007 | 06:47 PM
jonesymk2's Avatar
jonesymk2
anybody any ideas as this sounds similar problem 2 mine
Old May 23, 2007 | 08:29 PM
damncar's Avatar
damncar
Default iscv
try dismantling the idle speed control valve and was it out with carb cleaner or petrol. its sitting on ur drivers side strut top.
Also try cleaning the butterfly on ur throttle body & see if it makes any difference.
Good luck
Old May 25, 2007 | 07:21 PM
tonto's Avatar
tonto
Hi.You need to get the fuel pressure checked and adjusted.Also,any plugs to things like the MAP sensor,CO pot,MAF sensor,ISCvalve,Coil pack and CPS, Pull the plug off and then reconnect.This is a good way of cleaning the contacts in the plug.
Paul.
Old May 27, 2007 | 03:03 PM
D4nny8oy's Avatar
D4nny8oy
Fixing the bloody car...
Sounds like a MAP sensor problem mate. When they fail the ECU can't respond fast enough under load and sudden throttle openings as it's having to guess the air pressure which governs a lot of the running parameters.
I had a similar fault when I switched my 3i over to OFAC RS management and ballsed-up the wiring.
Like Tonto said, check the electrical connection to it, as well as all the vacuum pipes onto the inlet manifold.
Hope this helps.
Danny
Old May 27, 2007 | 03:16 PM
neil andeRSon's Avatar
neil andeRSon
just wondering m8 is it a black one out from the auto trader?
i phoned about it but just missed out..
Old Jun 7, 2007 | 12:53 PM
mk1trb's Avatar
mk1trb
Boost Junkie
i had this problem, changed the throttle position sensor and it was fine
Old Jul 4, 2007 | 08:20 PM
stevemex's Avatar
stevemex
Finaly got a map sensor to try from a mate and it worked !
Forgot about the post as nobody replied to it for months
cheers
RSmark84
Sep 13, 2015 01:29 PM
Eigdoog
Sep 13, 2015 05:46 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
