2wd and 4wd inlet cams!!
Old Feb 9, 2007 | 08:37 AM
lammylama's Avatar
lammylama
Default 2wd and 4wd inlet cams!!
Do 2wd and 4wd inlet cams differ in any way??
How do you tell the difference between a 2wd and a 4wd head too.
thanks
Old Feb 9, 2007 | 04:38 PM
No they are the same.
The easy way is to look at front around THERMOSTAT HOUSING, 2wd TWO BOLTS, 4wd THREE BOLTS.
Pretty sure that is right, also 2wd have boss on side for turbo damper 4wd does not.
Old Feb 9, 2007 | 06:27 PM
jon@work's Avatar
jon@work
I thought that the cams were different at the nose end where the front bearing fits ?
It was only the early 2wd heads that had 2 thermostat housing fixing bolts - later 2wd heads have 3 bolts as per 4x4.
2wd head has the water temp sender at the front of the driver's side, on a 4x4 head it is at the back od the passenger's side
Old Feb 9, 2007 | 07:47 PM
You could be right probably are, had not even thought about the bearings in 2wd!!
Did not know that about the heads though, my 88 sapph has two bolt head if that's any help.
Old Feb 9, 2007 | 08:57 PM
rabmc's Avatar
rabmc
3 door head have 2 bolts thermo housing , 2 wds have 3
4 wds are totally different shape
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
cos elle
Sep 25, 2015 09:52 AM
Chopshop85
Sep 12, 2015 06:42 PM
dojj
28
Sep 11, 2015 10:00 PM
