4wd calipier swap?
Old Feb 8, 2007 | 04:34 PM
cosrep's Avatar
cosrep
Default 4wd calipier swap?
Are the 2wd 4 pots a straight swap for the 4wd front caliper?
Old Feb 8, 2007 | 08:54 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Afraid not. Different offset I believe. Definately cannot just swop them.
Old Feb 12, 2007 | 02:48 PM
cosrep's Avatar
cosrep
Reason why I'm asking is I've just picked up a pair at an auto jumble sale for 20 euro I dont think the guy knew what they were
To fit them would I need 2wd discs as well? and if so would the standard lattice wheels clear the calipers?
Old Feb 12, 2007 | 02:58 PM
jon@work's Avatar
jon@work
I don't think you'll be able to fit 2wd discs onto the 4x4 hubs - the disc will foul the steering arm. You may be better off just selling the calipers on - at a profit of course.
Old Feb 12, 2007 | 05:12 PM
They may go on with 2wd discs and tappinng the lug holes to take bolt.
Se if you can get/borrow a set of 2wd discs to see if it all lines up, may need washer under lug to space slightly, but should go straihgt on when hole is tapped.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie brad
Sep 29, 2015 02:38 PM
grishenko45
Sep 9, 2015 12:58 PM
