Skimmed head
I have managed to warp my head, and it needs about 20 thou taking off to make it flat, is this going to have a big effect on the compression ratio?
will i need to get it re-mapped?
Take the head to someone like Ferriday Engineering and they can machine combustion chambers to keep same comp ratio.
Or use a thicker head gasket to keep comp ratio same
Don't forget to measure piston to valve clearence after skimming if you stick with std head gasket.
Go for a fuelling check as this will also show up any det caused by raised CR, 20 thou(0.5mm) is not a lot in terms of the swept volume of the piston into squish area of head so chances are unless right on limit of performance boost all ok.
Mc5506
Oct 5, 2015 09:57 PM
