plug reccomenations?
Old Feb 5, 2007 | 01:14 PM
shanemc's Avatar
shanemc
Default plug reccomenations?
i know its been asked before but i'd like to get the right set of plugs for my exact spec,ive a misfire when coming on boost and the plugs and then the phase sensor are the first things im going to change,
ive a 91 4x4,stage 3 spec,boosting to 18psi,what plugs do you reccomend?
thanks,
Shane
Old Feb 6, 2007 | 03:17 PM
Champion C57, or AGPR12PP8, was what I was told recently by a few tuners but C57 can apparantly give a lumpy idle.
Old Feb 6, 2007 | 07:12 PM
shanemc's Avatar
shanemc
nice one thanks,what make are the AGPR12PP8?champion aswell?what gap do you recommend?
cheers,
Shane
Old Feb 7, 2007 | 06:15 AM
The AGPR12PP8 are MOTORCRAFT(FORD).
The CHAMPION are just that champion.
As for gap I would use 0.6mm unless you have a group a coil, if not get one well worth the money, got mine from MATT LEWIS £32 delivered 01922 692424.
Then experiment with the gap as you should be able to open it up a bit, group a on mine(stg1) made idle much much better and improved low down imensly pulls a lot harder at lower revs, general running a lot smoother too.
Both plugs available easy enough, most places sell them.
Old Feb 7, 2007 | 11:44 AM
Twellsie's Avatar
Twellsie
ik27's on mine
Old Feb 7, 2007 | 11:48 AM
KSA-Cossie's Avatar
KSA-Cossie
Ford motorcraft 071c's finis code 1120834
Old Feb 7, 2007 | 12:00 PM
DAN P's Avatar
DAN P
071 s i used m8
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
