Wheel wobble still there! Could it be CV's or wheel bearings
Old Feb 2, 2007 | 02:45 PM
LeviA's Avatar
LeviA
Default Wheel wobble still there! Could it be CV's or wheel bearings
Right, replaced the spigots, tires, bushes and bottom ball joints. Wheels still wobble at 50 and over. So process of elimination can only mean either CV's or wheel bearings.
As the car is driven cold the wheels don't wobble as much but after 3 miles the problem gets worse. Could it be the CV's or wheel bearings?
Old Feb 3, 2007 | 10:57 AM
J9BBY's Avatar
J9BBY
Perehaps some rust or dirt behind the brake disks?? This would cause the wheels not to sit true and hence wobble, but i guess would also cause brake judder.
Pete.
Old Feb 3, 2007 | 11:53 AM
fatmike's Avatar
fatmike
have u used a DTI runout gauge and cheked that the hub is runing true ? if not could be a buckled rim have u tryed puting the back to rims on the front and see what happens ? or another set of wheels to see if it still is hapaning
Old Feb 4, 2007 | 03:33 PM
LeviA's Avatar
LeviA
Tried a different set of wheels and the problem is still there just not as much because of the standard rims being a much higher profile tire.
I'm at a loss what it could be now!
Old Feb 4, 2007 | 03:44 PM
fatmike's Avatar
fatmike
have u changed the brake discs ?
either its the discs or the hub is knackered which means the bearing is moving in the casing causing a unbalanced wheel.
Old Feb 4, 2007 | 05:30 PM
LeviA's Avatar
LeviA
Discs and pads were changed last week
Someone said it could be the prob or drive shaft out of balance but I hope not!
Old Feb 4, 2007 | 11:03 PM
fatmike's Avatar
fatmike
havent a clue thear mate soz have u had the wheels balanced
Old Feb 5, 2007 | 09:53 AM
LeviA's Avatar
LeviA
Cheers. No bother pal, they've been balanced about 5 times in 10 days and the rims are new. Got me baffled.
Old Feb 5, 2007 | 09:51 PM
s1 dean's Avatar
s1 dean
had exactly the same problem recently it was a sticky caliper on the drivers front on mine sounds weird i know but it wasn't pulling to one side or anything, was shaking like mad once driven for a few miles but fine when cold
when the pads were changed did the piston(s) go back easily? is it 2wd or 4wd?
Old Feb 6, 2007 | 07:25 AM
J9BBY's Avatar
J9BBY
Have you tried a different set of wheels???? Or tried these wheels on another car??
I bought a brand new set of wheels that did exactly the same thing. The wheels had been made badly. Sent them back and ended up getting no new wheels in return and no refund Robbing bastard. I'd put this to the back of my mind. Nuff said. Used a credit card ever since.
Old Feb 6, 2007 | 09:04 AM
Cawood's Avatar
Cawood
what about the TCA's? i had this prob n found it to be them
Old Feb 6, 2007 | 10:41 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll probably be the actual hub face itself
new ones cured the problem on the estate bt they were around the £100 each side plus bearings etc
remove the discs and clean the face where it mounts up properly with a wire grinder so that you can see the casting marks in it
it might be worth even knocking the studs out and making sure it's all smoth before getting new studs put back in again (at around 32 per stud it's cheaper than new hubs)
Old Feb 6, 2007 | 04:06 PM
LeviA's Avatar
LeviA
Pistons went back fine mate, I pealed back the rubbers and squirted some spray grease in too. It's 4x4 mate...
Old Feb 6, 2007 | 04:08 PM
LeviA's Avatar
LeviA
Tried the original wheels back on and the same thing happens to a lesser degree, it's dampened down because of the large profile on the orginal Saph wheels I think mate.
Old Feb 6, 2007 | 04:09 PM
LeviA's Avatar
LeviA
I had a 4 wheel geometry check done by a main dealer and they checked the track rod ends as I did when I put the new bearings in, but could well be worth a check! Cheers
Old Feb 6, 2007 | 04:12 PM
LeviA's Avatar
LeviA
100 quid each side Knowing my luck it'll be expensive. I could have bought a small African repulblic for the amount I've spend up to now on this Saph!
Old Feb 6, 2007 | 04:36 PM
dojj's Avatar
dojj
welcome to cosworth
don't worry, it could also be the inner tca bushes, the actual crossmember that has shifted, a wieght missing from the driveshaft
no one has mentioned checked the front prop for play, do that as well otherwise you may be needing new ankles
Old Feb 6, 2007 | 05:34 PM
LeviA's Avatar
LeviA
[/quote]
welcome to cosworth
no one has mentioned checked the front prop for play, do that as well otherwise you may be needing new ankles [/quote]
The wobble is more through the steering wheel than the floor pan, until you do about 60/70 then less so through the steering wheel and more through the chassis.
I just hope this Cosworth isn't as much of a money pit as the one in this photo was. God I despised that car so much lol
Old Feb 6, 2007 | 09:07 PM
dojj's Avatar
dojj
have you swaped the wheels around? as in side to side rather than front to back?
Old Feb 6, 2007 | 10:01 PM
LeviA's Avatar
LeviA
Yes mate, they've all been swapped diagonally.
Old Feb 7, 2007 | 06:21 PM
dojj's Avatar
dojj
discs is your next port of call
then hubs
after that, the petrol station
Old Feb 7, 2007 | 06:46 PM
LeviA's Avatar
LeviA
Discs and pads were done almost immediately. I'm guessing the hubs or track rods now. Head-doing
155lee
Oct 27, 2015 04:55 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
hopper350
Sep 4, 2015 12:53 AM
