They are not fouling as this was all checked before hand on a mock build before tightening it all up....
Ok cool... but they will be very close! The picture below is the same brake disc with a flat bell but with special track rod boots which give 4mm more clearance. Perhaps your bells are not inset as the pictures suggest. Anyhow they look much better than the old ones!
