How to get Chattering on a 4wd cossie????
Jan 27, 2007 | 02:53 PM
My mate has a 4wd cossie. Totally standard bar a NMS Gunship chip and an aftermarket exhaust.
Is it possible to make it chatter or flutter?
I know that this is not caused by the wastegate but the air rushing back on to the turbo blades when the turbo stalls.
It still runs the standard airbox.
Any ideas?
Many thanks.
Jan 27, 2007 | 02:59 PM
run a cone filter and it will do it
Jan 27, 2007 | 03:32 PM
And blank off the standard dump valve.
Jan 27, 2007 | 03:41 PM
I have a group a K&N cone filter and it does not do it.
Need to blank off dump valve or plug vac pipe to it.
Jan 27, 2007 | 08:37 PM
i run a nms setup on a T3 with a Ramair cone filter AND dump valve and it chatters till the cows come home
Jan 27, 2007 | 10:25 PM
blank off standard dump valve and u should get chatter whether u have airbox or con. mine does it everytime i even slighty coe off throttle.
Jan 28, 2007 | 01:57 PM
I got group a dump valve and drilled out the holes as far as poss without breaking it, god it's noisy now!!
Jan 28, 2007 | 02:00 PM
Cone filter and 500 cooler makes a difference , mines has a flump valve too and i get the best of both worlds , its mad loud for some reason
Jan 28, 2007 | 05:15 PM
The rs 500 cooler helps a great deal with chatter, im the same as rab, dump valve and a bad ass group a k&n filter, cant beat it
Jan 28, 2007 | 05:29 PM
i run a pipper cross cone filter and dump valve and it chatters like mad
Jan 29, 2007 | 11:39 AM
My chattering scares pedestrians hundreds of meters away, running RS500 I/C and a metal mesh cone filter, and the old broom handle where the dump valve was, it's LOUD.
Jan 29, 2007 | 01:56 PM
Yep, blank dump valve and blank off vac pipe
Jan 29, 2007 | 10:06 PM
I've been chattering away since July, but now turbo's starting to smoke because of it !
Jan 30, 2007 | 09:02 AM
Quote:
Yeah but, it's worth it
Jan 30, 2007 | 12:48 PM
Does it really mess the turbo up?
I had chattering on my cossie managed S1 for ages and it never effected the turbo.
Jan 31, 2007 | 05:17 PM
Got a massive foam filter on mine, stage 1 and it chatters and the dump valve is great as well.
For some reason I thought you got one or the other - either chatter or dump valve so was really suprised when picked up my new motor and had both. I loved it!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
