st24 overheating
Old Jan 27, 2007 | 09:39 AM
Richie1Craw's Avatar
Richie1Craw
Default st24 overheating
as in the title, when i'm driving around normally it's fine and on motorways, but i've only had the car a week and wanted to see what it would do, was away about 10mins and the fans started coming on rapid when i slowed down, so i stopped and left it running for five mins then switched it off for about 15 mins, then started it back up went to drive home and the temp gauge went to red????? haven't moved it since, the water seems fine in it.
also what's the best oil to use? i'm a bit of a mobil1 faithfull what grade should i use?
Old Jan 27, 2007 | 11:02 AM
mattxr3i's Avatar
mattxr3i
sounds like the famous water pump impellor has broken, get it fixed asap, and try and get a metal one! THe original is plastic and this gets brittle and shears off
Old Jan 29, 2007 | 02:55 PM
Richie1Craw
went to start the car up and it was fine for about 10 mins, then overheated again goin into the garage tomorrow to be checked, hope it is the water pump, bugger replacing the radiator, can you buy the metal 1 from ford? also my car has 58000miles what grade oil should i use?
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Mark Mawson
Aug 31, 2015 07:09 PM
madness23
Aug 4, 2005 12:36 PM
Thrush
14
Jul 6, 2005 08:42 PM
James_RST
17
Sep 21, 2004 07:55 PM
