Back wheels sticking!!!
Old Jan 22, 2007 | 07:37 AM
BM's Avatar
BM
Default Back wheels sticking!!!
If the cars been lying for a few day (handbrake on) and I go to use it, the back wheels stick
I need to really pull away hard so they come free...
Is it expensive and whats the cause
Old Jan 23, 2007 | 10:31 AM
wilmot's Avatar
wilmot
You dont say what car it is, buy never mind Drum or Disc. Sounds like they are rusting up, as the brakes were wet when you applied the hand brake, so the need a little shove and they become free.. This should not be much of a problem as once you have used your brakes a couple of times it should clear any rust on the Rotor.. a couple of helpful tips if this problem is persistant is to gently apply your brakes on very lightly on your last 1/4 mile home when its raining, to warm up the brakes slightly so they are dry when you apply the Handbrake, or leave the car in either 1st or Reverse gear and leave the handbrake off, reverse, if the car is facing downhill or 1st if its facing uphill..... If all this fails to help get a qualified mechanic to have a look at them for you.... Hope this helps.. Wilmot
Old Jan 23, 2007 | 10:28 PM
bortaf's Avatar
bortaf
If it's drums try some copper slip between the SIDE of the shoe and the back plate where it rubs
Old Jan 24, 2007 | 05:33 PM
More likely to be handbrake cable sticking, dont pull up so hard or just leave in gear if on flat, bung a new cable on.
Old Jan 28, 2007 | 01:51 AM
BM's Avatar
BM
Thanks for replies
its a 1995 Escort
Not had a problem since I posted this as ive been using it everyday
Will try the tips when its goin to be parked up for a few days
cheers
T666 FRS
Alloy wheels and ICE for sale
Nov 13, 2015 06:51 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
bassboy
Aug 8, 2015 10:21 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
