HELP 2ltr pinto conversion
Old Jan 21, 2007 | 06:57 PM
nick8saff's Avatar
nick8saff
Default HELP 2ltr pinto conversion
doing a 2ltr pinto conversion into my mates 1.3 mk2 escort.put the engine onto the 1.3 mounts and it didnt fit so im guessing we need the rs2000.also the sump is hitting the crossmember so do i need a different sump.
can we still use the original 1.3 4spd box
any help appreciated. could really do with parts tomorrow if anyone can help there to
Old Jan 21, 2007 | 07:16 PM
Alvyn's Avatar
Alvyn
if you've just got the ordinary sump you could cut and shut it by welding etc to fit so it misses the x member or just go and find the parts from a rs2000 doubt it will be for 2morrow thou you will need to get rs2000 mounts and sump and also gearbox as the 1.3 box will not mate up to the 2litre block,you will also have to move the gear stick hole back a bit also,exhaust runs on the other side also and few more things!
Old Jan 30, 2007 | 09:31 PM
ricky's Avatar
ricky
my m8 got a pinto turbo lying around from is mk1 he took it out
to put cossy in it he might sell it interestring
mk3ste
Oct 17, 2021 10:09 AM
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
