Why do you need a boost gauge?
Old Jan 21, 2007 | 02:35 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default Why do you need a boost gauge?
I know this is a really stupid question but i've never had a turbo car. Why do you need a boost gauge as I thought the actuator limits the boost anyway. I know this is probably a really stupid question
The saph i've bought has no after market gauges.
I intend to fit a boost, oil pressure and oil temp gauge anyway.
Old Jan 21, 2007 | 02:41 PM
Paddy's Avatar
Paddy
Legend
Same reason you have a temperature gauge!
So you can see when it's working ok and know when it's not
GARETH T's Avatar
GARETH T
they look cool
and of cause,, too much boost will fuck your engine very fast so its good to keep an eye on
Old Jan 21, 2007 | 02:44 PM
richm's Avatar
richm
and you can change the scale on it and impress ya mates when it reads 45
Old Jan 21, 2007 | 02:47 PM
GARETH T's Avatar
GARETH T
richm
i thought i was the only person doing that trick
Old Jan 21, 2007 | 02:59 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You don't need it, as said above its just to make sure its not boosting funny.
Steve.
Old Jan 21, 2007 | 03:00 PM
Jimboxr4x4's Avatar
Jimboxr4x4
I see. What could make the boost get too high?
Got a lot to learn about this new turbo lark
Old Jan 21, 2007 | 04:10 PM
Fiecos Dan's Avatar
Fiecos Dan
To much boost causes.
Faulty actuator,
Sticky wastegate,
Boost leak before the actuator.
Boost controller faulty.
Set up wrong.
Old Jan 21, 2007 | 04:16 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
or faulty boost gauge
Old Jan 21, 2007 | 04:26 PM
Fiecos Dan's Avatar
Fiecos Dan
As i said
Originally Posted by Fiecos Dan
Set up wrong.
Old Jan 21, 2007 | 04:51 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Cheers chaps. Picking it up tomorrow evening and can't wait
Not gonna drive hard though until I've changed all the oils, the cam belt and had it checked by a tuner.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
