Sierra cossie 4x4 boot
Old Jan 21, 2007 | 10:49 AM
mike23's Avatar
mike23
Default Sierra cossie 4x4 boot
Hi got a problem with my boot on my cossie , cant open it If i pull the release mechinism it does nothing, tried putting the key in the lock but wont turn anyone got any ideas how to sort this?? Help much appreciated...
Old Jan 21, 2007 | 02:52 PM
Sounds 2 me like ur boot catch has seized, get inside ur boot n try n open ur boot, then get some lubrication like wd40 and try n free the catch off.
Old Jan 21, 2007 | 04:04 PM
Alvyn's Avatar
Alvyn
drop the back seat and as you look at the lock mech there is a small bracket(that moves up and down slighty) that part connects to the release part that connects to the part that moves when you pull the lever and I'd say that it HAS dropped so you HAVE to push it back up so that the lever mets to it when you pull the release handle(get some one to move the lever inside and you'll see what I mean!
Old Jan 21, 2007 | 04:37 PM
mike23's Avatar
mike23
thanks for the replies , but how can i get in the boot because the levers for laying the seats down are in the boot side, or am i just being thick ??
Old Jan 21, 2007 | 05:28 PM
Alvyn's Avatar
Alvyn
Originally Posted by mike23
thanks for the replies but how can i get in the boot because the levers for laying the seats down are in the boot side, or am i just being thick ??
sorry my bad I was thinking about that as I have removed my catch of the small part of the seat in mine for this reason as my boot de- locked!
what I suggest you do is get some tape or a cloth around the lock and get some molegrips/slip jaw pliers and twist the lock anti clockwise and the clip that holds the lock in place will fall off and then you should be able to open it that way(then you will see what I mean in my 1st reply)
Old Jan 21, 2007 | 05:53 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine did that and it was the lock fooked.
charliecosworth
Aug 19, 2015 02:00 PM
Vincereese
Aug 15, 2015 06:24 PM
cossie4x4
Aug 14, 2015 06:29 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
