Lost 5th gear!!!
Old Jan 20, 2007 | 03:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Lost 5th gear!!!
Ok check this out........i fitted a new clutch on thursday everything went smoothly quite a simple job really, but for some reason I no longer have a 5th gear!!
The stick goes in and sits as if in 5th but when you bring the clutch up nothing happens you can just rev the engine but go no where!
So I disconected the selector rod and put it in 5th actualy using the rod that sticks out of the gearbox and still nothing!
I'm wandering if when I had the gearbox out something has moved inside preventing 5th from engaging?
Ther are no crunching sounds and all other gears work perfectly.
Any ideas?
Old Jan 20, 2007 | 05:10 PM
Aaroncast's Avatar
Aaroncast
i did (or may not have) read somewhere before you remove clutch leave in 5 th gear! .
Old Jan 20, 2007 | 05:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
hmmm........
Old Jan 20, 2007 | 05:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
........ I think that is only if you remove the drive shafts, which i didnt!
So shouldnt matter!
Old Jan 20, 2007 | 06:45 PM
SafeChav's Avatar
SafeChav
Shouldn't make a difference to be honest, thats usually to help with the setting up of the linkage.
Just purely bad luck i guess, but on the plus side, you can inspect 5th gear with the box on the car
Old Jan 20, 2007 | 07:52 PM
scotty86d's Avatar
scotty86d
i couldn't get third gear when i adjusted mine.i cocked up and didnt get it right. its pot lukc to some extent and most likely that
Old Jan 20, 2007 | 10:29 PM
gup's Avatar
gup
does sound like the gear linkage is out slightly does it crunch and pull away in all the other gears even in reverse
Old Jan 20, 2007 | 10:30 PM
SafeChav's Avatar
SafeChav
He said hes selected the gear manually from underneath and still no drive?
Old Jan 20, 2007 | 10:33 PM
gup's Avatar
gup
my bad
Old Jan 20, 2007 | 11:18 PM
SafeChav's Avatar
SafeChav
Old Jan 21, 2007 | 06:44 AM
JesseT's Avatar
JesseT
You didn't drain gearbox oil by removing a small screw, did you?
Old Jan 21, 2007 | 11:49 AM
SafeChav's Avatar
SafeChav
Ahhhhhhhhhhhhhh........................
Good thinking JesseT
Old Jan 22, 2007 | 03:48 PM
Karlos G's Avatar
Karlos G
Balls Deep!
errr......... I started to then thought it was getting a bit long for a drain plug and screwed it back in!
WHy? What is it for??
I'm guessing badness has happened!
Old Jan 22, 2007 | 03:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah regards the gear linkage posts, i engaged 5th without having it connected to ensure it wasnt just me not getting it right so i'm certain its not that cos there was still no drive, i can put it in and out of 5th with out using the clutch either connected to the gear linkage or not!! and yup all other gears work perfectly!
Whats this screw all about then?
and how can i inspect 5th with the box still on the car?
Cheers!
Old Jan 22, 2007 | 04:45 PM
SafeChav's Avatar
SafeChav
If my memory serves me correctly that is the locking pin for the 5th gear selector fork!
Not a big drama, its fixable!
get yer haynes manual out
Old Jan 22, 2007 | 05:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
So as 5th gear is accessable without taking the box off, i might be able to relocate it!! Is there a cover or something i need to remove to get at it then?
Like you say Haines manual time!
Old Jan 22, 2007 | 05:21 PM
SafeChav's Avatar
SafeChav
You can access 5th gear just by removing the end case, which is lucky for you, to access 4/3/2/1 you have to split the casing open!
Haynes manual indeed!
Old Jan 23, 2007 | 07:34 AM
JesseT's Avatar
JesseT
It's not the 5th gearlocking pin, but an axle for a lever. I'll try to find a picture of it.
Anyhow, the remedy is to remove the gearbox mounts.
Lower the gearbox and engine (the engine mount stays put) about 10cm.
Open the end case of the gearbox.
Put parts to their correct places.
Refit everything.
Edit:
Ok, have a look at here:
http://www.kolumbus.fi/~w444776/JT_k...ox/rebuild.zip
picture 8243 specially.
edit2:
Old Jan 23, 2007 | 04:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
5th gear has landed!!
Just took the cover off the side of the gearbox and low and behold the fork was sitting there on the bottom, where I had unscrewed it!
So removed screw, lighned it up and screwed back in!
Didnt even have to move engine or gearbox, managed to do it all on the car!
Thanks everyone for your help!!!
Karlos.
Old Jan 23, 2007 | 04:58 PM
JesseT's Avatar
JesseT
Always glad to help people who want to DIY.
Old Jan 23, 2007 | 08:23 PM
SafeChav's Avatar
SafeChav
Well done, that must of been well fiddly to do without dropping enough but still jobs a good un
(Don't be a muppet next time )
timsrs
Nov 13, 2018 11:48 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
The Youth.
Sep 30, 2015 09:59 PM
deathrider666
Sep 28, 2015 06:12 PM
