2. Fuel line OR bigger fuel pump ?
Old Jan 16, 2007 | 01:17 PM
FE's Avatar
FE
Default 2. Fuel line OR bigger fuel pump ?
...as above...I am trying to get the max out of a T35.63 and later move on to a T4 (or GT..).
The current setup includes WRC head gasket, Stage 3 head and ARP studs, so it could handle 30 psi...
The question is: bosch 044 pump or 2. fuel line ????
Any advice, suggestions ?
Thx !
Old Jan 16, 2007 | 10:19 PM
NUTS RuS's Avatar
NUTS RuS
Pump first, lines next if needed
Old Jan 16, 2007 | 11:56 PM
Tarren's Avatar
Tarren
Old Jan 17, 2007 | 09:21 AM
FE's Avatar
FE
Thx !
What would be the advantage of installing a 2. fuel line ?
Old Jan 17, 2007 | 11:31 AM
NUTS RuS's Avatar
NUTS RuS
What do you mean by 2. ?
Old Jan 17, 2007 | 12:37 PM
FE's Avatar
FE
...by 2. I mean the extra fuel line...(with standart fuel pump...)
Old Jan 17, 2007 | 07:27 PM
NUTS RuS's Avatar
NUTS RuS
Whats an extra fuel line going to do if the pumps now tired and worn ?
You will just have weak pressure in both lines
Old Jan 17, 2007 | 07:48 PM
FE's Avatar
FE
Maybe I'm not clear enough, sorry...
The setup will consist of:
- 1 "044" pump with 1 fuel line (bigger fuel line)
OR
- 2 "041" pumps (standart pump) with 2 fuel lines (original fuel line)
Pressure in both lines should be ok, right ?
Old Jan 17, 2007 | 09:44 PM
bud-weis's Avatar
bud-weis
Football Cwazy
one 044 pump can supply enough fuel for any T34 by miles,even on standard fuel lines
IF they are tired and worn it would be good practice to change them for new ones,but not to gain anything other than a smoother flow.
using 2 pumps at that power level would create more hassle than it's worth to be honest.
I run one 044 pump,with new aeroquipped lines at around 420bhp,and they will be fine for at least another 100bhp as they are (pump and lines)
Old Jan 17, 2007 | 10:01 PM
NUTS RuS's Avatar
NUTS RuS
OR
There will be no gains in option 2
Old Jan 18, 2007 | 01:42 PM
FE's Avatar
FE
What kind of hassle do you expect ?
Old Jan 18, 2007 | 03:28 PM
jon@work's Avatar
jon@work
Why bother making up a special mount for the pump and sorting the 2x inlets and 2x outlets? What happens if you get the T4 fitted and eventually find that you're running over 400 brake and one pump fails?
Save yourself hassle. Fit a 044 pump (and change the fuel filter whilst you're at it).
Old Jan 18, 2007 | 04:48 PM
C0S_TURBO's Avatar
C0S_TURBO
Sometihing else worth considering is replacing or up grading the power supply to the pump as well. Found it an advantage when I went for a power upgrade on my saph.
Old Jan 19, 2007 | 04:24 PM
FE's Avatar
FE
Good point !..THX !
Old Jan 19, 2007 | 06:19 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Yes, good point,should be done to EVERY cossie running above standard power IMO
Old Jan 21, 2007 | 12:28 PM
FE's Avatar
FE
Still haven't decided what to do....I think I will go for a extra fuel line with an extra fuel pump...
And raise the boost about 5 psi...
Old Jan 21, 2007 | 12:49 PM
rapidcossie's Avatar
rapidcossie
why complicate things?
A 044 pump is easy capable of supplying the fuel you need.
Old Jan 22, 2007 | 08:27 AM
FE's Avatar
FE
The 044 pump also requires a bigger fuel line, right ?
With an extra standart fuel pump, I would only need another standart fuel line...
Old Jan 22, 2007 | 09:36 AM
jon@work's Avatar
jon@work
No - standard fuel line is a direct fit to the 044
Old Jan 22, 2007 | 02:42 PM
FE's Avatar
FE
It's a direct fit...but will a standart fuel line also maximise the output of the 044 ?...or do I need a bigger fuel line ?
Old Jan 22, 2007 | 03:01 PM
bud-weis's Avatar
bud-weis
Football Cwazy
on standard lines you will be fine at 450bhp providing they are in good nick,some people run way in excess of this actually so i don't think that is a worry at all.
you DO need a fitting kit for the 044 pump,it's just a screw in adapter to make the one end suitable for connection to the standard setup (costs about £10)
Old Jan 22, 2007 | 04:08 PM
focus 4x4's Avatar
focus 4x4
If it helps im running 2 044 pumps and 2 filters using 2 -6 fuel lines up to 8 green injectors on a RS500 plenum along with a T4 turbo on pectel software (T2)
Old Jan 24, 2007 | 04:14 PM
FE's Avatar
FE
Nice setup !!!
what power is that mean machine delivering ??
- Why did you chose for 2 fuellines and 2 pumps ?
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
