diesel forum
Old Jan 12, 2007 | 05:13 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default diesel forum
hey guys took on a guys car at work were the guy striped the engine then left having a few probs with this 1 can any one advise me of a good diesel site its a 99/00 fiesta endura di 1800
thanks tommy
Old Jan 12, 2007 | 05:31 PM
antony215's Avatar
antony215
Escort Rs Turbo
Whats problems are you having with it
Old Jan 12, 2007 | 05:42 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
got the engine in got the pump decoded bla bla bla went to fire up and it ran then cut out so started bleading the injectors and pump ,then the bottom sprocket on the timing chain the locating pin snapted ,so the t/b tensioner sprung and bent a valve, so i changed the valve etc and the sprocket but when putting the pully bolt on with the gun the pully was rotating when the bolt was fully tightend( can turn pully by hand just when the impact of the gun was on it ) just didnt seem right the boss says we need it out the garage by the end of the month so just looking for some pointers, i have fully rebuilt
3 zetec turbo engines and 1 cossie and all are still going very strong
but i havent got a f..king clue when it comes to diesels
thanks tommy
Old Jan 12, 2007 | 06:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
Are you sure the locating pin is in the bottom pully
Old Jan 12, 2007 | 07:05 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
there is only a locating pin on the sprocket and that is located as we just finished the pump timing ,dont know if you know the engines ,but its a chain from crank(sprocket) to pump then a belt from pump to cam shite set me thinks, but anyhow bottom pully is just flush and it sits hard against the sprocket ,thats why i am confused it still moves ??
any help would be great
and thanks so far for the replies
tommy
Old Jan 13, 2007 | 07:42 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
any 1 help me out on this 1
Old Jan 13, 2007 | 09:48 PM
davecosworth's Avatar
davecosworth
IM BACK
it is just a pressure fit pulley isnt it mate you sure you have all the washers on the pulley bolt
Old Jan 14, 2007 | 09:42 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thats what i thought
another guy stripted the engine and i was left to rebiuld it everything else looks good but this looked dodgy ,,any 1 know if its ment to have a washer infront of the bolt (the bolt looks like a bonded washer is on it but there also has a recess on the pully that looks like there could be a washer missing)
thanks for the help guys need to get this done within the month
Old Jan 14, 2007 | 10:16 AM
davecosworth
IM BACK
could you get a picture of it and post it up as i had to rebuild one of these but just cant rememeber maybe a picture will famillairise me with it again,
Old Jan 14, 2007 | 11:58 AM
antony215's Avatar
antony215
Escort Rs Turbo
I would have thought it would have had a locating pin like you do on a cam pully or as davecosworth says a big washer to make it a pressure fit pic's would help
Old Jan 14, 2007 | 03:04 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks guys i will get picts tomor . there is no locating pin and just to ad there are none on the cam either, alot of fords are like this i think i know zetec s etc dont have them so as for the locating pin i think more of a washer ,i phoned ford and they said by there discription it just looked like a bolt with a washer on the bolt as 1 peice so ????
but will get pics tomor
davecosworth> did you have any probs with this build mate.
Old Jan 14, 2007 | 03:22 PM
davecosworth
IM BACK
no the only thing i had prblems was with fuel pressure mate,
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
