erst s2 fuel prob help ???????????????
Old Jan 8, 2007 | 04:38 PM
stuartrst's Avatar
stuartrst
Default erst s2 fuel prob help ???????????????
hi i have fuel from the pump threw the filter to the unit the four red hoses that go to the injecters are dry the one that comes off the side has pressure.any views thanks.
Old Jan 8, 2007 | 05:28 PM
g1234's Avatar
g1234
i had same problem and could i hell as like figure it out for weeks first of allmake shure plenty of fuel in car because if there is only a bit it can affect fuel pressure also have you had car in bits at all cos a bad earth could cause switch not to activate valve in metering head (that was my problem in the end lack of fuel altho there was plenty in and bad earth to ecu) i thought mine was nackered and 100 quid and 2 good metering heads after i got it working so if it is nackered i have 2 which i no works as i checked them on my car
Old Jan 8, 2007 | 06:53 PM
stuartrst's Avatar
stuartrst
cheers mate have pm you with a few more questions
Old Jan 8, 2007 | 07:02 PM
SafeChav's Avatar
SafeChav
I'd unbolt the metering head from the base first off and check the plunger is free, if turn it upside down it should sink down by itself, thats how free moving it needs to be
Old Jan 9, 2007 | 08:01 PM
g1234's Avatar
g1234
have you made any progress mate to solving problem
Old Jan 10, 2007 | 07:53 PM
stuartrst's Avatar
stuartrst
put Ł20 petrol in no change checked as many earths as i could find still nothing
Old Jan 10, 2007 | 09:39 PM
SafeChav's Avatar
SafeChav
Have you done what i said above?
Old Jan 11, 2007 | 07:01 PM
stuartrst's Avatar
stuartrst
do you mean take the top bit which the red fuel hoses connect to off the metering unit and there is a small shaft of metal is that what i am checking.
Old Jan 11, 2007 | 08:25 PM
g1234's Avatar
g1234
no he means the plunger under the air box or filter also when you tried to turn it over did you do it yourself or have you got help because the best way to do it is take injector pipes off and filter box or induction whatever is on and get someone to turn engine over and push flap down a few times to see if there is fuel to pipes that will check wether plunger is free aswell without taking it off
Old Jan 11, 2007 | 08:59 PM
SafeChav's Avatar
SafeChav
Correct
Old Jan 12, 2007 | 06:08 PM
stuartrst's Avatar
stuartrst
have bought new metering unit off a mate fitting tomorrow will let you know. the thing i cant work out the car drove to the garage fine had a head gasket done put back together without touching the metering unit and now no fuel i hope it works tomorrow .
Old Jan 13, 2007 | 01:25 PM
SafeChav's Avatar
SafeChav
Let us know how you get on
Old Jan 14, 2007 | 12:28 PM
stuartrst's Avatar
stuartrst
All done chaps replaced the top bit started first time thanks for your help...
Old Jan 14, 2007 | 02:14 PM
SafeChav's Avatar
SafeChav
timsrs
Nov 13, 2018 11:48 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
