tappits or shims??
Old Jan 8, 2007 | 11:00 AM
truthordare's Avatar
truthordare
Omnomnomnom
Default tappits or shims??
Hi all, wonder if anyone can help, I have a 2.5 V6 Mondeo 130,000 miles on the clock and its making a strange noise, its like a fast ticking that sounds like its coming from the drivers side, its not very loud when idling but very loud when revved, also a lot faster as the engine speeds up, am unsure if the V6 is tappits or shims and could this be the cause?? or pulleys that would speed up with revs, I just wondered if anyone else had come across this and how they remedied it??
any help is greatly appreciated
Debs
Old Jan 8, 2007 | 06:16 PM
dave green's Avatar
dave green
hydraulic mate
Old Jan 9, 2007 | 06:22 PM
truthordare
Omnomnomnom
hydraulic tappits, that answers that one thanks dave, just need to know about my funny noise now
Debs
Old Jan 17, 2007 | 05:04 PM
Japfan's Avatar
Japfan
The Hydraulic tappets work via oil pressure to sustain them, usually a oil seal around the top of the tappet goes thus allowing the oil to leak out. This means that the hydraulic tappet requires replacing. If you are lucky only one, maybe two will have gone. Last time i bought one of these for a Ford they cost between £10 and £15 each. The only way to check for sure is to remove the rocker covers and inspect the hydraulic tappets, and knackered ones will be loose on the top.
i thankyou
Old Jan 17, 2007 | 06:49 PM
truthordare
Omnomnomnom
thanks for that, don't I have to replace the whole lot though?? it is quite high mileage.
Debs
CrOwSoN15
Sep 14, 2015 11:33 AM
grishenko45
Sep 9, 2015 12:58 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Si t
Escort MK 5 / MK 6
May 10, 2007 07:58 PM
truthordare
Jan 8, 2007 06:15 PM
