Pictures, video & Photoshop ForumIf you want to show off your photoshop skills, share pics and videos of your car or other cars you've found, here's the place to go.
this was the inspiration for my fiesta. hideing wiring in inner wings etc makes them look so much better and clean and not a massive job. its a work of art [/img]
i fancy a bit of EFI cvh myself, ive got a manifold floating around in my garage only instead of saying efi it says ford on it, the inlet came out of a 1.4 cvh escort its a 1996 model is it possible to use this or does it have to come of a fiesta rs turbo.?
The top half is fine to use but the bottom half has tiny ports on the edge that bolts to the head, you'd either have to port it or use the FRST lower half!
I have used the "FORD" top half in a conversion before but i can't remember on who's car!
Thanks a lot, so in order to use the best way would be by using a rail from frst and throttle body? think they look smart with the ford logo on and as its free its even better..
