How to request - Different wheels- Now started. Take Looky
Have a read here, its beyond what your going to do, but some of the principals are the same
http://www.pixeladdiction.com/bb/art...rtid=16&page=1
Take 2 pictures and edit / merge them into 1
includes most things to do with modding cars to get you started
http://www.digimods.co.uk/tutorials/tutorials.htm
Originally Posted by L33 BYT
Ok, so im here at the moment.
How do I get the final finish to try and blend in the wheels?
There are lot of ways to do it, probably the easiest is to join the two wheel images into 1 layer then adjust the contrast and lightness to blen the colour into that of the wheels already i.e. lighten the images until the black turns to the grey that matches the existing tyres, or like I mentioned above if you remove the tyres you then wont need to. You could then just adjust the layer visabilty slightly.
Try that for starters and see how you get on..........
The way i do wheel changes is i find the picture that i want to take the wheels off and then i just cut round the actual wheel, some people like to have a bit of the tyre with the alloy but the problem with that is you see 2 different colours of tyre in the chop which you can see on your first posted pic of the MG.
Looks like your getting the hang of it now though, hope you find my advice helpful and good luck with your future chops etc
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
