12 door mk4 Escort zetec. Guess whos back... back again! 15/3/10
Old Dec 7, 2006 | 10:45 PM
macturbo's Avatar
macturbo
Default 12 door mk4 Escort zetec. Guess whos back... back again! 15/3/10
Well here it is. This has been my project since about january 05.
I bought the car nearly 4 years ago as a 1.4 cvh twin weber carb. Its a 4 door gl model. I know its a 4 door but the shell is mint, as in its never been welded anywhere. Also I have 2 kids so its easier to get the kids in being a 4 door.
Unfortunately I lost the pics of the car when it was completley standard, but I do have lots of pics of it being stripped, parts added etc.
when the car is completed it will have had the following done,
Koni adjustables, rs spec bumpers, and bodykit
sierra cossy rear disc conversion, erst front disc conversion
full efi conversion, rst s1 recaros's, rs s2 rear seats
m3 mirrors with side repeators(originals to be smoothed), twin headlight conversion
delocked and cat 1 alarm and immobiliser fitted, multiTlock fitted,
rs bonnet (possibly might get badboyed), 1800 16valve zetec turbo engine to be fitted (engine originally from a XR3i 130 model)
white dials for clocks and heater controls, on board efi fuel computer
full respray in ford imperial blue, smoked rear lights
full electric pack, full stainless steel exhaust
lowered 40mm, rst lsd gearbox
There is probably loads of bits ive missed so Al add them later, time for some pics
Hope you like the pictures,
Old Dec 8, 2006 | 07:26 AM
fezzajsy's Avatar
fezzajsy
looks good, all the best with it
Old Dec 8, 2006 | 12:14 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
ive never seen a 5 door witha 90 spec boot spoiler befor and it REALLY makes a difference looks good mate get some more pics up of the car
Old Dec 8, 2006 | 02:35 PM
rich_frst's Avatar
rich_frst
Old Dec 8, 2006 | 04:24 PM
macturbo's Avatar
macturbo
Thanks for the thumbs up people
This is a budget build but still it should look pretty good, I hope.
Ive bought a 90 spec escort RS turbo for its parts as the shell is rotten.
Also had new number plates made for it
Time for more pics,
This pic shows how aggressive the front end looks from a distance
Old Dec 8, 2006 | 04:38 PM
bassboy's Avatar
bassboy
whats the spec of the engine mate
bassboy
Old Dec 8, 2006 | 04:58 PM
RichieST's Avatar
RichieST
oops double post
Old Dec 8, 2006 | 04:59 PM
RichieST's Avatar
RichieST
top work mate!!! Definately a bit different, and fair play for doing it!
Not too sure about the grammar tho on the number plates! Shouldnt it read, I wish my lass was as fast as this?
Old Dec 8, 2006 | 07:21 PM
zippyobrien's Avatar
zippyobrien
thats really cool,
looks sweet from the rear quarter angle, get some rs1600i spats on it and get the arches pulle dout like thay do on the d1 drift cars,
looks sweet
beest of luck
Old Dec 9, 2006 | 12:58 AM
p-38-king's Avatar
p-38-king
niiiiiiiiiice lol
Old Dec 9, 2006 | 09:47 PM
benjodeaves's Avatar
benjodeaves
good look i doin a zetecturb k3 fiesta
Old Dec 10, 2006 | 02:03 AM
SaqsS2turbo's Avatar
SaqsS2turbo
FUKIN SHHHWWWWEEEEEEETTTTTTTTT!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Old Dec 10, 2006 | 02:00 PM
marky_g's Avatar
marky_g
Fleet Manager
find a 3 door shell
Old Dec 10, 2006 | 04:20 PM
macturbo's Avatar
macturbo
Originally Posted by marky_g
find a 3 door shell
If I hadnt of bought this car I would have done a 3 door shell mate. Ive had this car for nearly 4 years now and I love it, no chance of getting rid of it. Ive never seen a cleaner mk4 shell than this either. All the sills, rear arches, doors, battery tray, fuse box,floor pans, inner wings etc are original and the car has never been welded. I have replaced the bonnet as ive fitted a turbo 1 instead and the front wings are being replaced as they are scabby at the bottom otherwise its mint. Once its painted in a couple weeks time it will much better...... hopefully!
I have bought another turbo bonnet now as cant make my mind wether to keep the badboy bonnet or not. Have alook and see what you think, I have pics of it with the badboy bonnet and how it currently looks with its standard turbo bonnet.
This is how it looked this morning,
I started removing the sunstrip but the remembered that I am gonna replace the windsreen with a heated screen incase was wondering why its half missing,
I think I prefer this bonnet, but I just cant make my mind
this is what it now looks like,
Its hard to believe the carpet was mint when I fitted it a couple month back,
White dials now fitted,
Also the heater controls now match,
Old Dec 10, 2006 | 05:28 PM
SaqsS2turbo
ahoii this car is jokes keep it up very interesting the black non badboy bonnet luks better
Old Dec 11, 2006 | 06:48 PM
macturbo's Avatar
macturbo
bassboy
Alright matey. the engine spec is basicaly the poverty spec, lol.
Im using a 3mm decompression plate and 2 headgaskets to lower the compression. The engine had been stripped, cleaned and put back together with new gaskests and seals etc. It still has the 130 XR3i cams fitted. I drilled and tapped the head myself for the ERST exhaust manifold to fit. Ive also blanked the gas recirculation on the front of the block as the turbo fouls it and ive drilled and tapped a new hole in the rear to compensate. Also fitted is a drain pipe to the sump for the turbo oil return.
So everything is basicaly standard including the turbo but it will be running beige injectors, chipped ECU, front mount cooler, uprated fuel pump, power boost valve etc.
I know its not the biggest engine spec in the world, but it will have to do for now.
Old Dec 16, 2006 | 04:27 PM
macturbo's Avatar
macturbo
Right time for an update people. Ive been busy gutting the donor RS so I can get all the suspension cleaned and painted. The shell is absolutely rotten, its got more holes than tetley tea bag. All that will be left tomorrow will be a shell with its doors and glass left, nothing else. I have the shell and ID provisionly sold to a lad from manchester so hopefully it will be away next week so I can carry on with my escort. The donor RS is given up all its goodies, including Koni adjustables, suspension is all polybushed so it should hold well on the road. I still have to find an ecu and injectors yet then I will have everything to complete this project at long last.
Some pics of the donor car looking sorry for itself,
Old Dec 16, 2006 | 05:14 PM
SaqsS2turbo
SWEEEEEEETTTTTTTT THATT CARRR HASS OFFICALLYY BEEN PI...... RAPEDDDDDDDDD!!!!!!!!!!!
Old Dec 16, 2006 | 05:59 PM
Nice project there ,the black bonnet is the one to use ,also how much did the donar car cost you
Old Dec 16, 2006 | 06:30 PM
macturbo's Avatar
macturbo
I paid Ł200 for the donar car. It had a few bits missing like,
both bumpers, recaro's, bonnet, fuel pump, metering unit.
I did get it with a piper cam, chipped ECU, polybushed suspension, koni adjustables, bailey dump valve, stainless steel plates for the underside of the bonnet vents (the vents were in the car when the bonnet got nicked), stainless steel strut top rings, boost gauge, full set of 5 RS alloys with almost new tyres, genuine RS turbo bodykit, braided flexi brake hoses, brand new front calipers, discs and pads, T3 turbo (with almost no play at all on the shaft) Vecta alarm and immobiliser, full stainless steel exhaust, brand new slam panel (not fitted still in the car) 4 new floor pans, (3 of them tacked in place)Brand new front wings. The engine has just been rebuilt hasnt done any miles yet and it includes a brand new sump etc.
Someone nicked the parts I listed above as missing when my mate had it and he just lost interest in it after that.
Old Dec 16, 2006 | 06:55 PM
SaqsS2turbo
Old Dec 19, 2006 | 07:21 PM
macturbo's Avatar
macturbo
Well Ive been busy again this past couple of days. The white rs donor car is officially dead. I spent all sunday stripping the back suspension off fuel tank out etc. Ive just ordered brand new wheel bearings, as the car has been off the road a couple years, already had new bottom arms, track rod ends, calipers, discs and pads for it and it will all be polybushed and sitting on koni adjustables and 30mm lowering springs. Im now in the process of cleaning up the stub axles, rear arms, anti roll bars etc ready for paint. Only thing I cant decide is the colour in which to paint the suspension. The car's colour is gonna be ford imperial blue, all the underside is gonna painted with black underseal to protect it so I just ned to decide on the suspension now, I was thinking yellow and maybe painting the fuel tank to match. anybody any ideas or pics?
I hope its gonna be a canny car when finished, a 4 door RS Turbo
Old Dec 19, 2006 | 07:25 PM
SaqsS2turbo
lots of rapeing going on
Old Dec 22, 2006 | 09:39 PM
macturbo's Avatar
macturbo
Little update,
Ive gettin a lend of a small sandblast machine so Ive been busy cleaning up the hubs, towing eye etc. I also tret the car to new front wheel bearings, the rear wheel bearings will get done when I get round to sandblasting the rear hubs etc. Ive also bought a brand new clutch
As you can see ive started painting 1 hub and 1 stub axle just to get a look at what they will look like in yellow. Now im unsure wether yellow is such a good idea and I may change the colour to black.
I know the sandblasting is the best you have seen but its my 1st time and I only used a small clarks sandblaster. Also I noticed that the 2 front hubs dont match so I am gonna get another hub so they match. I know it doesnt make any difference but I like things to be right. Opinions please!!!
Old Dec 22, 2006 | 10:02 PM
SaqsS2turbo
paint the rest of it allll goooooood
Old Dec 23, 2006 | 09:02 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Brilliant project matey keep it up
Old Dec 23, 2006 | 10:41 PM
macturbo's Avatar
macturbo
cheers matey,
Old Jan 2, 2007 | 03:02 PM
p-38-king's Avatar
p-38-king
nice one mate and thanks for the pms on the zetec turbo conversion , its looking good so far the yellow looks good mate and will stand out a bit but its all up to you , keep up the good work matey top work so far
Old Jan 4, 2007 | 11:34 AM
macturbo's Avatar
macturbo
Well time for a small update I think. Ive sold my transit to pay for the paint work on my car so now Ive stripped the engine bay out completely over the past couple days. This morning the lads from the paint shop turned up to collect the car. They reckon it will be back next friday with the engine bay all painted ready for me to fit the zetec turbo engine then its going back for them to strip the rest of the car and paint it.
Its going ford imperial blue
What do you think?
Old Jan 4, 2007 | 11:35 AM
rich_frst's Avatar
rich_frst
Old Jan 4, 2007 | 11:45 AM
Fastas's Avatar
Fastas
Should be good
Old Jan 4, 2007 | 12:39 PM
ram's Avatar
ram
Has a large member
4 door good to see something different. bargain with the donor car too
Old Jan 4, 2007 | 01:16 PM
dsgtrain's Avatar
dsgtrain
Bit of a diffrent colour on a Escort but should be good!
Old Jan 4, 2007 | 06:29 PM
p-38-king's Avatar
p-38-king
cant wait to see it come back!
Old Jan 4, 2007 | 07:32 PM
slimwynn's Avatar
slimwynn
my first escort was a five door eclips in blue it looked lovely with mondeo alloys
good luck with your car m8 looking good
Old Jan 4, 2007 | 07:43 PM
macturbo's Avatar
macturbo
Thanks guys . I need to pull my finger out now and sort a couple of bits ready for it coming back. Ive already bought a brand new braided oil feed turbo pipe today, just need to sort an ecu, map sensor and injectors to get it running.
Old Jan 4, 2007 | 11:11 PM
fezzajsy's Avatar
fezzajsy
Old Jan 4, 2007 | 11:12 PM
SaqsS2turbo
Old Jan 8, 2007 | 10:08 PM
benjodeaves
hello m8 looks good heres a pic of my engine doin well as im out of work no money an 3 kids
Old Jan 20, 2007 | 08:30 PM
macturbo's Avatar
macturbo
Well its back from the paint shop with the engine bay all done. Once its up and running its going back for the rest of the car to be done. The painter wants it running to make it easier for him to move it around. Anyway here is a few pics with the newly painted bay and ive started straight away fitting the new engine. What do you think so far?
