cosmetic head gasket question ( reusable?)
Old Nov 26, 2006 | 06:10 PM
xr4x4rs's Avatar
xr4x4rs
Default cosmetic head gasket question ( reusable?)
are the 3 layer head gaskets reusable
reason i ask is ive just fitted one to my engine, but now i want to do a rebuild using my 200 block, the gasket was fitted a couple of months ago and the engine has just been sat on a stand
not even fired up
so was wondering if i could re use it or just bin it and buy a new one
thanks
Old Nov 26, 2006 | 06:21 PM
costina's Avatar
costina
Live long and prosper!!
No problem they can be re-used as your engine has not run
My mate's had a Norris design's built YB with a triple layer WRC one he had to take the head off for mods and simon Norris said not to re-use his old one
Make your own mind up
Paul
Old Nov 26, 2006 | 06:24 PM
lawnsy's Avatar
lawnsy
id just use it if it not been run............its had no heat through it...
Old Nov 26, 2006 | 06:25 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i forgot to put the oil return bungs in mine.....20 seconds later off....install and back on....mountune 3 layer 28lb boost and still sweeeeeet
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
After my recent experience, I wouldn't use a Cometic gasket atall, I reckon.
Old Nov 26, 2006 | 06:29 PM
neilm's Avatar
neilm
What would you recommend Christian as I need to do one on my Stage III 3 Door ?
Old Nov 26, 2006 | 06:32 PM
PeterLucas's Avatar
PeterLucas
I thought you could re-use them even if they had been run?
Old Nov 26, 2006 | 07:28 PM
col cos1's Avatar
col cos1
your head and block surface has to be like glass to get a proper bite with no leaks on the cometic ones but if your heads been skimmed and you get your block decked then no problem and Ł100 rather than Ł375 for wrc,and to be honest your only going to use it once eh......
Old Nov 26, 2006 | 07:47 PM
DENNIS's Avatar
DENNIS
they can only be used once, they have pressed layers on them and when torqued down they are crushed to seal, if your are rebuilding your motor then the cost of a new gasket should be included for a proper job ...
Old Nov 26, 2006 | 08:02 PM
Tangodeltasierra3's Avatar
Tangodeltasierra3
Who makes the cosmetic headgaskets ? Max Factor ?
Old Nov 26, 2006 | 08:03 PM
Butch.'s Avatar
Butch.
had one of these on one of my saph's about 3 years ago i ran my saph for 400 miles on a new engine took the head off to replace a valve re used the gasket and it was fine for 8000 miles until it melted and i was running greys, t34, 30 psi......
but if it was to happen to me now i would use a new one for the sake of 100 quid...
smitsturbo's Avatar
smitsturbo
"COSMETIC GASGETS"
Old Nov 26, 2006 | 08:28 PM
Rs Gary's Avatar
Rs Gary
NEVER REUSE A HEADGASKET end of
cheeRS gary
AKA shrek
Old Nov 26, 2006 | 09:17 PM
abdr500's Avatar
abdr500
never re use a headgasket even if it has 10 layers and renew head bolts to
Old Nov 26, 2006 | 11:08 PM
xr4x4rs's Avatar
xr4x4rs
ok thanks for the replies lads
i know i spelt it wrong lol, was in a rush as i had to go out
think it sbest i buy a new one then to be on safe side
and reading baout oil grommets? dont think mine had any come to think of it if there rubber thats is anyhow
head bolts im using arp stud and nut kit
but now if im going to do the build i get my 200 block machined and use my long studs
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
