Twin dellorto 45's or single dellorto 48
Old Nov 26, 2006 | 12:04 PM
vette376's Avatar
vette376
Default Twin dellorto 45's or single dellorto 48
got a 2.0 pinto and upgrading carbs. Have been offered twin dellorto 45's but they are expensive. I have also been offered a single 48 and i have been told it can do the same jod as the twin 45's.
Anyone know if this is the case, or am i better getting the twins??
Old Nov 26, 2006 | 03:04 PM
Wardy257's Avatar
Wardy257
What spec is your pinto?
Old Nov 26, 2006 | 05:34 PM
vette376's Avatar
vette376
its a 2.0L 1988 pinto. FR33 Kent Cam, Lightened flywheel, standard head ported & polished (valves original). Standard pistons.
Old Nov 26, 2006 | 07:51 PM
Wardy257's Avatar
Wardy257
What carb are you using at the moment?
Old Nov 26, 2006 | 08:11 PM
Nookerhead's Avatar
Nookerhead
A single 48 is nowhere near as good as a set of 45's, the spec of your engine wouldnt warrant the use of 45's,try 40's they cost a lot less, if you were to run high compression ie 11:1 or more and big valve head n wild cam etc then 45's and 48's are the way forward, but in this instance 40's with the right chokes will be perfect.
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
