escort cosworth 1993 amal valve
HI. My escort cosworth amal valve has got 2 outlet pipes on it and the multiplug is the same type as an injector plug. I've got a sierra amal valve with the 3 outlet pipes on it with 2 spade conectors on it. Can i cut my standerd multi plug to fit the sierra amal? I don't want to blow anything,so would i be able to do it or would i need to buy a proper escort cosworth one? Thanks. Regards Kerry
Hi. Thanks for your reply. Can you tell me where i can get a new or second hand one from,as the 3 pipe one i bought the other day from Burtons said that is the only one they list for the escort? Thanks .Regards Kerry
