rover v8 not starting
Old Nov 20, 2006 | 10:39 PM
scotty86d's Avatar
scotty86d
Default rover v8 not starting
a friend of mine has a 3.5 carb b8 in his mk3 capri and it isnt starting. its got new plugs, good spark from all of them. compression is i think something like 125-135 in all cylinders(is this ok). what fuel pressure does it need(has a guage just after the reg)? and also what is the order for the ht leads. any diagrams would be helpful. cheers
scott
Old Nov 22, 2006 | 04:52 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default pressure
its 15 bar when normal but when started its 30 bar i think
Old Nov 22, 2006 | 07:01 PM
sexr3i's Avatar
sexr3i
isn't it
haynes might tell you more? invaluable when doin any kind of conversion.
Old Nov 22, 2006 | 08:55 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default leave it with me
ill have a look and see what i can dig up for you what car is the engine out of
Old Nov 23, 2006 | 10:09 PM
scotty86d's Avatar
scotty86d
an early carbd sd1 i think
any info would be great chap(s)
thanks
Old Nov 24, 2006 | 07:52 PM
15 to 30 BAR what planet is this guy on ?
Around 4/6 PSI is normal for SU carbs anymore and they flood.
My dad has 4 litre TVR V8 in his xr4i, can find out order if you want ?
Old Nov 27, 2006 | 11:12 AM
scotty86d's Avatar
scotty86d
think it said 4 bar when we were trying to start it, but it jsut wouldnt turn over. so if its got fuel, spark and i hope thats good compression we can assume its timing??
Old Dec 9, 2006 | 10:22 AM
djmillsy's Avatar
djmillsy
Fife Radge
oh fuck sorry i was talking about oil pressure
Old Dec 9, 2006 | 03:34 PM
dave green's Avatar
dave green
Thats miles out for oil pressue. Rover V8s only run 38psi 2.5bar max
Dave
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
