Knocking
Old Nov 18, 2006 | 08:43 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default Knocking
Theres a knocking coming from the front drivers side of my mk 6 escort and i dont know what it is any ideas its got new bsll joint and the sturtd are only 4 year old
Old Nov 19, 2006 | 06:19 PM
neds2rst's Avatar
neds2rst
hi mate well first try jackinng car up and check wheel is tight cause sometimes on ground the weight holds it out and feels tight if not try drive shaft nut is tight and bent so it cant loosen
Old Nov 23, 2006 | 06:08 PM
djmillsy's Avatar
djmillsy
Fife Radge
the wheels tight the sturt was a bit loose should i change that ive tightened it up but still knocking and the cv boot is burst im going to change it when its dry
Old Nov 28, 2006 | 04:05 PM
djmillsy's Avatar
djmillsy
Fife Radge
its ok i found out the anti roll bar buch is fucked and thats what the noise is
Old Dec 1, 2006 | 06:40 PM
saphc05's Avatar
saphc05
quite common those m8
Old Dec 1, 2006 | 06:44 PM
djmillsy's Avatar
djmillsy
Fife Radge
aye they were only £2.50 each from tms and now the back wheel bearing is giving up lol
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
BRAM
Sep 8, 2015 07:11 AM
adam151082
Aug 30, 2015 08:34 AM
