S2 RST Rev counter
Old Nov 16, 2006 | 09:43 AM
bigchez's Avatar
bigchez
Default S2 RST Rev counter
Hi all,
Recently bought a S2. The rev counter is not working properly. It has an aftermarket set of dials fitted called plasmadials which look white during the day, but when dark you can go from blue to green and adjust the backlight. They look very bling, but unfortunatley my rev counter is not working!
When the car is ticking over the counter shows approx 1k rpm so is fairly accurate. However it never goes above 2500. It doesn't go erratic, just doesn't go over 2500.
Any ideas? The speedo works fine (and is actually surprisingly accurate to 95 measured against my sat nav). The fuel gauge is a bit slow to come up but does work, as does the temp gauge.
Is it likely the needle has been put back wrong after they were fitted? I have done some research on here and passionford, and read that the feed is a green wire from the dizzy. I think that it is not an intermittant connection as it is constantly reading low, rather than sometimes working and sometimes not. Any help greatly appreciated. DIY cheap fix would be best as I'm skint for 2 weeks!
Old Nov 16, 2006 | 10:11 AM
SafeChav's Avatar
SafeChav
Mk4 rev counters are shit
Usually if the need is wrong it will read wrong everywhere.
Try getting another rev counter to compare to
Old Nov 16, 2006 | 10:29 AM
bigchez's Avatar
bigchez
Thanks for replying. Do you think there's no chance of me fixing it? Coul i get a new rev counter bit (if that makes sense!) rather than replacing the whole dash?
Cheers.
Old Nov 16, 2006 | 10:32 AM
SafeChav's Avatar
SafeChav
I doubt it to be honest, and it would be much easier just to replace it if it is the rev counter itself.
Yes you can simply replace the rev counter part, although i can guarantee the trial and error of getting the needle on correctly takes longer that actually fitting the rev counter itself
Old Nov 16, 2006 | 10:36 AM
bigchez's Avatar
bigchez
Is it a dash out job to fit the new counter? would you replace the wiring feeds as well? any idea of the cost for a new one?
(sorry for all the qn's!!!)
Old Nov 16, 2006 | 10:45 AM
SafeChav's Avatar
SafeChav
No, you can get it out with the steering wheel on aswell but i would recommend taking it off if you can!
As long as there is continuity in the green wire then it should be fine (and it goes to the coil, not the dizzy btw)
I personally would just find a second hand one in a scrap yard to try
Old Nov 16, 2006 | 10:51 AM
bigchez's Avatar
bigchez
Ok, thanks a lot for all your help! Will have a go at the weekend, cue lots of 'I took my dash to bits and now it won't go back together threads!'
Coil/Dizzy............same differen ce! Meh !
Old Nov 16, 2006 | 10:55 AM
SafeChav's Avatar
SafeChav
Its easy enough to do, remove the horn from the wheel and then you will need a 22mm to get the wheel off (REMEMBERING to take the steering lock off before you start smashing the steering wheel with a hammer because it doesnt come off )
Then theres 2 screws holding the black surround on at the top, then pull it out (2 clips at the bottom which can be tight)
Then 2 more screws holding the clocks in.
Bet you a jam tart it takes you longer getting the speedo cable off than anything else
Old Nov 20, 2006 | 12:19 AM
b_kennedy's Avatar
b_kennedy
so where did you get plasma dials for a mk4. thanks??
Old Nov 21, 2006 | 11:39 AM
bigchez's Avatar
bigchez
The shop is auto tint design. The ad is in the front cover of this month's FF. Def have plasma dials listed for Mk4 RST. £69+£3.50 p&p. Their number is 0113 289 1500 web www.autotintdesign.com
Old Nov 21, 2006 | 10:17 PM
b_kennedy's Avatar
b_kennedy
thanks very much!!!
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
