master cylinder for escort
can i get a bugger master cylinder to fit a rs turbo as mine has just sh## its self and a have cossie brakes up front 4 pots so i would like to upgrade it if i can
In that case.........your answer is a big fat no.
The master cylinders on Fords are reidiculously big, you compare it to the equivalent from another manufacturer, you will struggle to find a 22mm amongst the competiton.
I believe there are some 26mm items out there but you will have to change the servo aswell, and thats far from being a bolt on mod.
What number is on the side of your master cylinder
Adam Graham
Sep 6, 2015 06:04 AM
