4wd head on 2wd block?
Old Nov 13, 2006 | 05:21 PM
costina's Avatar
costina
Live long and prosper!!
Default 4wd head on 2wd block?
can this be done on std 2wd pistons????even with a cometic head gasket which is thicker???
Old Nov 13, 2006 | 06:32 PM
marco polo's Avatar
marco polo
hi mate
if you use a 2wd bottom end or 2wd pistons on a 4wd head you will up the compression by .3
so lays say if the 4wd head on 205 or 200 block and 2wd pistons are standard ( not been skimed or dected in any way,) the compression will be 8:3:1
same way if you use 2wd head/ on 205 or 200 block with 4wd pistons it lowers the comprssion by .3 so it will be 7:7:1
hope this helps
marco
jessie_rs
62
Aug 6, 2019 09:27 PM
dojj
28
Sep 11, 2015 10:00 PM
kevin36
Sep 8, 2015 12:23 PM
rsstav
Sep 7, 2015 04:43 AM
hopper350
Sep 4, 2015 12:53 AM
