how do you put a breather port in a rocker cover?
i need to put a breather port in a new rocker cover i just got, i have seen the breather ports on ebay, but is there a way to get them in? does the port need to be welded in etc?
Mine is drilled and tapped for an aeroquip fitting,i also had to machine the cover to take the fitting...
Pretty sure you can get a similar fitting without the threaded top and just a pipe to jubilee clip a hose on to....
Get down you local Plumbing shop have a look whot they have to offer take the hose with you to get the right size end
My m8 got mine and he's some thing to do with plumbing
The as NIGHTDIVVA said just get the cover drilled and tapped
Wot paint do i need to get that finish
Steve
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
