Saph cosworth very low oil pressure. Whats wrong???
Old Nov 11, 2006 | 05:31 AM
Kirbycossie's Avatar
Kirbycossie
Default Saph cosworth very low oil pressure. Whats wrong???
My father has 91 stg 3 saph that runs really well but oil light comes on on tick over. We fitted oil pressure guage and it reads next to nothing on tickover and barely gets past 20 psi at high revs. The engine does not knock although some lifter noise is present at tickover. could someone please shed some light on the problem . Many thanks Stacey
Old Nov 12, 2006 | 07:25 PM
Kirbycossie
Any ideas as to the problem would be helpful.
We`re DESPERATE.
Old Nov 12, 2006 | 07:27 PM
rapidcossie's Avatar
rapidcossie
confirm your prob with another gauge first.
if its still not getin ggod pressure then it sounds like a oil pump at least
Old Nov 12, 2006 | 10:12 PM
Alvyn's Avatar
Alvyn
has it just gone low ALL of a sudden or after having some work done on it?
is it 2 or 4x4?
Old Nov 13, 2006 | 06:58 AM
J9BBY's Avatar
J9BBY
Could be a veriety of things;
Blocked oil strainer
Oil pump past its' best
Big end bearings on their last legs
I take it there is enough oil in it and it's the correct grade?!
It's just a process of elimination. You could try a flush and see if that makes any difference, but unlikely. Next step that I'd do is take the sump off and check the strainer for blockages then take it from there.
Don' drive the car mean time as you'll ruin the whole engine.
Best of luck.
Pete.
Old Nov 13, 2006 | 05:30 PM
Kirbycossie
Had low pressure since bought a month ago. The swine who sold it to us had took wire off pressure switch and we didnt notice!. Its a 4x4 so would that mean engine out to get to the pump? big ends do not knock.
Old Nov 14, 2006 | 07:02 AM
J9BBY's Avatar
J9BBY
Oh hey, that's too bad. I feel for you.
Pump is in the sump. So only need to take sump off, however front diff is bolted to sump and front near side drive shaft goes through the sump so these need to come off too. Is a bit of a pain in the arse.
Best of luck. Let me know how you get on.
Rgds,
Pete.
Old Nov 14, 2006 | 08:02 AM
Dave Henshall's Avatar
Dave Henshall
you are not using mobil 1 0w40 oil are you...? if so, this is far too thin
needs a 10-40 or 10-50 oil, fuly synthetic
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Dubs44
Aug 21, 2015 02:42 PM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
