Cossie Running Gear
Old Nov 10, 2006 | 06:51 PM
UncleFester's Avatar
UncleFester
Default Cossie Running Gear
Can someone tell me wether the running gear on the Sierra XR4/i is the same as the Siera cossie ?
If so what all is different besides the engine ?
cheeRS
Old Nov 12, 2006 | 01:06 PM
UncleFester
Bump
Old Nov 12, 2006 | 03:25 PM
Wardy257's Avatar
Wardy257
Everything is pretty much the same apart from 2wd gearboxes. The rear diffs, beams etc are all interchangeable. 2wd front hubs and brakes are different and there are a few minor supension mount differences along with thicker ARBs on the Cossies.
Old Nov 12, 2006 | 05:01 PM
cossie4is dad's Avatar
cossie4is dad
Default Re: Cossie Running Gear
cheeRS
Are you thinking of doing one ?
Steve. (XR4i Cossie Turbo Owner)
Old Nov 14, 2006 | 01:17 AM
UncleFester
Looking to build a Fiecos
Was wondering as it would be handier to get a XR4 and take the floor out of it and put into the Feista than cutting up a Cossie to do the same thing with
It would also be handy to be able to fit some of the rear running gear in anticipation of the cossie engine. And in doing it in this way i'll save a good bit (i hope) just buying Cossie parts and not a whole car.
Would the XR4 Gearbox be the same as the cossie one (4X4)?
cheeRS again
Old Nov 14, 2006 | 03:38 PM
cossie4is dad
cheeRS again
A XR4i is 2wd and was fitted with a type9 gearbox.
The early XR4x4s was also fitted with a 4x4 version of the type9 gearbox
Later MT75 boxes out of 2.9 4x4s might fit ?
Steve.
James Porter
Oct 28, 2015 12:17 PM
YODI
Aug 30, 2015 01:12 PM
James Porter
Aug 26, 2015 10:51 PM
knight19770
Aug 4, 2015 12:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
