Greddy Profec B Spec 2 Boost Controller Settings ??????
Old Nov 9, 2006 | 11:49 AM
Daxcossie's Avatar
Daxcossie
Default Greddy Profec B Spec 2 Boost Controller Settings ??????
ok.
Ive just fitted a Profec B boost controller for the 1st time and was wondering what settings I should use as a starting point for the following:-
Set
Gain
Start boost
Warning
Limiter
I plan on holding 28psi and also have a lower setting of 10 psi set into the controller.
Engine info:-
2WD Cosworth YB, T35 - .55, Siemens black injectors, MSD chip.
Thanks in advance for any comments.
Old Nov 10, 2006 | 12:01 PM
Daxcossie's Avatar
Daxcossie
I guess that Im the only one running one of these controllers and that setup will be made by trial and error
gchristophi
Aug 31, 2015 10:36 PM
FlashRS
Aug 30, 2015 08:07 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Steve Escos
Aug 24, 2015 07:56 AM
Escortdriver1
Jul 31, 2015 02:36 PM
