idling issue
Old Nov 6, 2006 | 06:57 PM
radiant red's Avatar
radiant red
Default idling issue
my saff is playing up again,after a bit of a thrashin the other night she decided to stop idling......i have checked for air leaks,split vac hoses tried a map sensor on had a bloody good look about and cant see much wrong!!
soon as i pick the rpm up its a little lumpy sounds a bit rich but will run ok once going just will not idle at all.
Anyone had similer
Old Nov 6, 2006 | 09:06 PM
Alvyn's Avatar
Alvyn
is the IDLE SCREW bolt still at the bottom of the throttle body? as they have been known to fall out
Old Nov 6, 2006 | 09:40 PM
radiant red
i have a swedish style inlet mate so i can see my throttle body and all seems well i have fuel and ignition so surely can only be an air leak,gonna whip inlet off tom have a good look around.
thanks for reply mate
Mark_
14
Jan 16, 2016 05:27 PM
fordrallycar
Sep 30, 2015 07:57 PM
SMILER258
Sep 28, 2015 09:04 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
