cosworth cam belt
Nov 5, 2006 | 09:51 AM
cosworth cam belt
what way do you turn the cambelt tensioner clockwise or anticlockwise to tension the belt when changing the cambelt thank alot dave
Nov 5, 2006 | 10:29 AM
Turn it clock wise, if you do it the other way it will rub thermostat housing.
Nov 5, 2006 | 10:41 AM
Nov 5, 2006 | 11:09 AM
Quote:
Anti-clockwise I think m8
Try it and find out,sure if you do it clockwise it lowers the belt,which makes it touch thermostat housing
Anti-clockwise lifts the belt up into a vertical position,so the belt clears thermostat housing
IIRC
Nov 5, 2006 | 11:12 AM
Just checked the autodata cd and definitely says turn tensioner clock wise.
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
cameron2
Aug 25, 2015 07:18 AM
taylora1409
Aug 12, 2015 12:06 PM
