Suspension on a KA?
Old Nov 3, 2006 | 01:50 PM
needloweringblocks's Avatar
needloweringblocks
Default Suspension on a KA?
I thought i'd stick it in here as I'm guessing the suspension is pretty generic across some of the smaller fords.
I'm having trouble getting to the bushes on the front suspension arms.
I have taken the nuts out of the bushes, but can't work out how to get the arm out.
I also have to take the macpherson strut out, and can't work out how to get the top nut undone.
I know it's with an allen key, but is that holding the sping compressed? I don't want to undo the top block and have the spring come flying out!
Should I put the spring compressors onto the spring before undoing the top bolt on the car??
Old Nov 3, 2006 | 02:50 PM
St3V3_C's Avatar
St3V3_C
About the top nuts, there are usually two - one above to hold the whole strut assembly to the car. Then once you take that out, there is another holing the spring seat and bearing etc.
So, undo the top one with a ring spanner while holding with an allen key, and you can take out the whole strut. Then you can dismantle with your spring compressors. Be careful...
Not sure on the bushes sorry. Any chance of a pic?
Old Nov 3, 2006 | 04:16 PM
needloweringblocks
excellent. thats what i thought.
the bushes are the front suspension arm bush at the rear of the front suspension arm
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
