How do you check the timing with verniers??
Old Nov 1, 2006 | 03:28 PM
escortcosrs's Avatar
escortcosrs
Default How do you check the timing with verniers??
Hi Guys
I have just changed the cam seal as per my other post but before I start the car I want to check its still timed right. I looked in the for manuel and I know where the bottom pully should be and the dizzy pully, only problem is I have verniers with no markings like the standard cams have. How do I know these are right?
Thanks
Old Nov 1, 2006 | 03:29 PM
kjc300's Avatar
kjc300
what make verniers are they??
Old Nov 1, 2006 | 03:30 PM
escortcosrs
not sure mate they are red with silver centres no markings on them at all including make? Do the lubes in the cams them selves that the verniers slide into tell you anything?
Thanks
Old Nov 1, 2006 | 03:43 PM
kjc300's Avatar
kjc300
Damn, mine are kent cams and the word 'cams' on them is where the arrows should be. So on yours I don't know!!
I believe the keyways should face outwards though iirc (opposite where the arrows would be) But don't take my word for it!!
Somebody will confirm for you (as well as say "consult your tuner" )
Old Nov 1, 2006 | 04:05 PM
escortcosrs
Thanks for you reply, if I can find out where the cam lubs should be at TDC I can finish the job.
Thanks again
Old Nov 1, 2006 | 05:12 PM
SafeChav's Avatar
SafeChav
The woodruff key on the cam should be at 6 o'clock, or as very close to it as possible being as you have a vernier!
Just remember to spin it over 2 full revolutions by hand before u attempt to start it
EDIT
This is for a CVH my mistake
Old Nov 1, 2006 | 05:16 PM
escortcosrs
Thanks anyway safe chav
Old Nov 1, 2006 | 05:26 PM
Stu @ M Developments's Avatar
PassionFords Creator
Exhaust woodruff 9pm
Inlet woodruff 3pm.
That will at least allow it to run, although if you turned it over with it wrong you have either:
A) Done about Ł1K worth of damage.
B) Used your 9th life...
Best of luck.
Old Nov 1, 2006 | 05:33 PM
Moonie's Avatar
Moonie
Get you exhaust cam set up later this evening then, you will have to wait untill tomorrow afternoon to set up the inlet.
Old Nov 2, 2006 | 07:59 AM
escortcosrs
Thanks guys all sorted although I did have trouble finding the groove on the rotor arm, it starts up and runs though. Can you get the rotor arm timing far out? Looking at the ford manuel there should be mark I think mine has worn away.
Old Nov 2, 2006 | 02:05 PM
escortcosrs
Took the car out for a spin before to check everything was ok. Oil leak seems to be sorted now gave it abit of boost etc and it didn't blow anything out the seal.
Only thing I noticed was the car felt a little flat off boost, Im still not convinced that I have the dizzy wheels timed up correct, as there are no clear markings of where it should be. In the service manual it shows the rotor arm should be at about 2oclock position so I set it to that but cant see any markings to get it spot on? Is there anything on the wheel and block its self.
Also I lined the bottom pulled up with the crank position sensor pickup point that's next to the grove in the bottom pulley is this correct or should it be lined up with the grove, its just my mate reckons it should be on the grove but the service manual picture looks likes it from the pickup.
Thanks
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
