quick relay question
Old Oct 29, 2006 | 02:43 PM
16vzetec's Avatar
16vzetec
Default quick relay question
im trying to find the fuel pump relay on the 1990 xr3i efi.
can someone tell me which one it is please?
Old Oct 30, 2006 | 06:13 PM
davidnormanuk's Avatar
davidnormanuk
Its the pink relay under the dash. If you look up from the drivers footwell you should see it.
Old Oct 31, 2006 | 12:30 PM
16vzetec's Avatar
16vzetec
oh someone else told me it was the yellow one under the dash?!?!?!
Old Nov 3, 2006 | 09:10 PM
SafeChav's Avatar
SafeChav
If your car is EFI then it will be yellow yes
Whats the problem you are having as its rare for those to pack up
Old Nov 3, 2006 | 09:25 PM
allbluepete's Avatar
allbluepete
was just away to ask the same question,know its not the pink one though cos the efi cars aint got a pink one,thats why i was asking really as every scort i have had has had a pink fuel relay and noticed the lack of said pinkiness
Old Nov 3, 2006 | 09:29 PM
SafeChav's Avatar
SafeChav
You need not bother now
The reason the early 89 and before cars have pink relays is because they are tachometric relays, as the cars have no ECU's. The late ones are EFI, so the ECU controls the relay, hence why its more reliable
If you ever get a fuel pump problem on an EFI, 99.9% of the time the inertia switch will need reseting
Old Nov 4, 2006 | 12:22 AM
16vzetec's Avatar
16vzetec
i have no fuel pump but i think it may be the megasquirt playing up.
i will find out tomorrow when i get someone to look at it
Old Nov 4, 2006 | 11:12 AM
SafeChav's Avatar
SafeChav
You have no fuel pump?
Old Nov 4, 2006 | 11:31 AM
16vzetec's Avatar
16vzetec
well its not working!
SafeChav's Avatar
SafeChav
Ah i see.
You wana be checking the inertia switch thats always a prime suspect!
Underneath the spare wheel.....
Old Nov 4, 2006 | 11:35 AM
16vzetec's Avatar
16vzetec
done that.
pump works as i have put power down the wire and it goes.
but i think its the megasquirt
Old Nov 4, 2006 | 11:58 AM
SafeChav's Avatar
SafeChav
Then its guna be trial and error i think.
Problem is its got megqsquirt no-one else is going to know how its wired etc
Old Nov 4, 2006 | 04:23 PM
Wardy257's Avatar
Wardy257
What? Why is an ECU controlled relay more reliable than a tachometric relay? They are both subject to poor connections and water damage.
Old Nov 4, 2006 | 09:32 PM
16vzetec's Avatar
16vzetec
it was a short in the loom.
i got it sorted.
then i had a major misshap.
i nipped 2 wires in my inlet manifold by mistake and its fried my loom.
absolutely gutted now.
cant believe my bad luck is continuing.
got to take wholecar loom out and start again.
very pissed off to say the least
Old Nov 5, 2006 | 11:41 AM
SafeChav's Avatar
SafeChav
Because the relays in MFi cars and alike firstly are very primitive and poorly made, but not only that they are all very under-rated. I dont think theres a MK3/4 on the planet that hasnt melted its relay, as soon as the pump gets a bit old and starts drawing a little more current they just burn out. They are rated 16A which is BORDER LINE for requirements.
The relay on an EFI car is rated at 30A, so there is A LOT less chance of failure/fire
Old Nov 5, 2006 | 11:42 AM
SafeChav's Avatar
SafeChav
i got it sorted.
What wires did you cut? And presumably you did them at the same time for this to happen
Old Nov 5, 2006 | 12:06 PM
Wardy257's Avatar
Wardy257
The tachometric relays are more advanced than the later relays, hence 'tachometric'. I fuel pump should only draw 4 amps, so a 16 amp rating is not a problem. If your pump starts drawing more than 10 amps your pump is the problem, not the relay.
Old Nov 5, 2006 | 12:11 PM
SafeChav's Avatar
SafeChav
Yes i am aware the relay in an EFI car is just an industry standard SPST relay, but in terms of quality and reliability it is SUPERIOR to the tachometric items in MK3/4's.
Surely if a tachometric relay was so technologically advanced compared to an ECU cars today would still use them - which they don't.
Tachometric relays are cheap pieces of shit used to overcome the problem of not having an ECU on an MFI car.
Old Nov 5, 2006 | 12:57 PM
Wardy257's Avatar
Wardy257
Who said a tachometric relay is more advanced than an ECU?
Why is not having an ECU a problem on MFI cars? Most people would say the opposite.
Old Nov 5, 2006 | 01:04 PM
SafeChav's Avatar
SafeChav
By that comment you are saying tachometric relays are better, but they're not, as i said they are cheap pieces of shit with poor construction quality used to overcome not having an ECU because a car is MFI.
And of course having an ECU is better in 99% of ways, MFI is known for being a big pile of wank as well as a lot of limitations - and thats WHEN its working properly........
Old Nov 5, 2006 | 08:44 PM
16vzetec's Avatar
16vzetec
cut the tps wires.
have spent all day stripping car and rewiring it.
pain in the bloody arse
Old Nov 5, 2006 | 08:50 PM
SafeChav's Avatar
SafeChav
cut the tps wires.
TPS???
Throttle position sensor wires? That fried your loom?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
