Pre '86 CVH cross-hatch head castings
Hi,
I've got two 81SM6090 cross-hatch heads from an '82 and an '85 CVH.
Both heads are 1.3 casting (same intake valve dia, but smaller exhaust valve dia [1.3: 34mm/1.6: 37mm] than the 1.6 casting as stock)
According to pumaracing.co.uk, the cross-hatch heads are the best CVH ones for valve size upgrade and porting (due to thicker walls).
Do you reckon that despite being 1.3, a +2mm intake valve (from 42mm) upgrade can be done on these castings?
cheers
cheers
The whole cumbustion chamber obviously will be different. There are also quite many different cross-hatch cvh heads; 1.3, 1.6 and even EFI. I doubt that the pumaracing statement is valid on all of these just because of the cross-hatch.
Thanks for the comment guys.
It's also the casting number that matches 81MS6090, but as I haven't seen a 1.6 of the same type to compare mine to, you might just be right.
However I think the combustion chambers are the same on 1.3 and 1.6 carb engines.
Originally Posted by JesseT
...I doubt that the pumaracing statement is valid on all of these just because of the cross-hatch.
1.3 engines have smaller bores i believe so therefore small combustion chambers aswell.
The part number is only really relevant to the casting year (1981), hence the 1.3 casting, and some have letters such as BRA after
The valve angles are the same too, I assume the radius of the hemispheric chamber dome is the same as well.
Would be interesting to know, as an engine swap is out of question at the mo. It all depends on my budget after the shell's repairs have been paid for.
mk3ste
Oct 17, 2021 10:09 AM
Mc5506
Oct 5, 2015 09:57 PM
