3 door cosworth,4x4
Old Oct 19, 2006 | 01:03 AM
Garnes Racing's Avatar
Garnes Racing
Default 3 door cosworth,4x4
some track phothos and the build prosses,the car was built in 10 days,you can see att the photos what we started whit.
http://s86.photobucket.com/albums/k102/garnesracing/
Old Oct 19, 2006 | 06:11 AM
Old Oct 19, 2006 | 12:10 PM
Brian's Avatar
Brian
Brian
Old Oct 19, 2006 | 02:09 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Old Oct 19, 2006 | 03:51 PM
Garnes Racing
specs: jenspeed head,bd14 cams,dobble valvesprings,modified inlet,
30mm pleniumspacer,turbonetic super 60 turbo(ar82 turbin housing),
670cc injektors,3" in/out rs 500 cooler+++++
362 horsepower at the wheels at 1.5 bar boost,now running 2 bar!
10x17 et 14 rims!
Old Oct 19, 2006 | 05:09 PM
JHS's Avatar
JHS
Pictures:
Old Oct 19, 2006 | 09:16 PM
Garnes Racing
hvordan fikk du bildene opp slik? data er ikke min sterke side!
Old Oct 20, 2006 | 02:19 AM
Vic's Avatar
Vic
whoa!!!
are they 9x17 et14 on the front as well???
Old Oct 20, 2006 | 02:58 AM
Vic's Avatar
Vic
oh and what size tyres are you using on the front and rear??
Old Oct 20, 2006 | 09:09 AM
Garnes Racing
it`s 10 inc front and rear! 245/35 on now,going to change to 225/40 so
it can be lowerd more
Old Oct 20, 2006 | 09:27 AM
Nick500's Avatar
Nick500
Old Nov 13, 2006 | 10:07 PM
Garnes Racing
car has now changed owner,I kept the engine.
traded it for a white 3 door 2wd.
so now drifting time!
Old Nov 26, 2006 | 02:53 AM
mikke's Avatar
mikke
bruker du photobucket geir. ? da trykker du pĺ den řverste linken istedfpr den nederste.. sĺ fĺr du opp bildene slik
its a shame you sold this car geir. althoug the white you have got .gonna be a killer too
keep it up mate and post some piccies for us
Old Nov 26, 2006 | 04:23 AM
Garnes Racing
pictures are coming of new car soon,just need a gearbox and diff and sump to fit the engine
Old Nov 26, 2006 | 09:46 AM
XR4iCosworth24v's Avatar
XR4iCosworth24v
I see on some of the pics that you also have the prob that your front wheels are coming out a lot.
I also have a 3 door with 4x4. If i drive through a hole or somethng, the arches cut into my tires.
Now are my wheels even deeper in thatn yours, so I would ask if you have the same problem, and if not, how did you do it?
Thanks already.
Old Nov 26, 2006 | 01:26 PM
mikke's Avatar
mikke
thats good. will send you the sump tomorow.
Old Nov 26, 2006 | 02:02 PM
Garnes Racing
Thanks already.
I run very stiff setings on the coilovers,no rub at all.
best way to make it to stop rubbing is to cut/trim arches and bodykit.
Old Nov 26, 2006 | 02:43 PM
fezzajsy's Avatar
fezzajsy
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
COSWORLD
Aug 14, 2015 07:40 AM
c14rks
Aug 11, 2015 05:17 PM
